When I run sudo apt upgrade, I get the following:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
wine-stable winehq-stable
0 to upgrade, 0 to newly install, 0 to remove and 2 not to upgrade.
If I try to sudo apt install wine-stable, it reports that there are broken dependencies:
The following packages have unmet dependencies.
wine-stable : Depends: wine-stable-i386 (= 5.0.0~bionic)
Depends: wine-stable-amd64 (= 5.0.0~bionic) but 4.0.3~bionic is to be installed
and despite "is to be installed", it transpires that version is already installed. I ran apt list -a wine-stable-amd64 and see:
Listing... Done
wine-stable-amd64/bionic 5.0.0~bionic amd64 [upgradable from: 4.0.3~bionic]
wine-stable-amd64/bionic 4.0.4~bionic amd64
wine-stable-amd64/bionic,now 4.0.3~bionic amd64 [installed,upgradable to: 5.0.0~bionic]
wine-stable-amd64/bionic 4.0.2~bionic amd64
wine-stable-amd64/bionic 4.0.1~bionic amd64
wine-stable-amd64/bionic 4.0~bionic amd64
wine-stable-amd64/bionic 3.0.5~bionic amd64
wine-stable-amd64/bionic 3.0.4~bionic amd64
wine-stable-amd64/bionic 3.0.3~bionic amd64
wine-stable-amd64/bionic 3.0.2~bionic amd64
wine-stable-amd64/bionic 3.0.1~bionic amd64
Now to my mind wine-stable-amd64 ought to just have updated itself to 5.0.0~bionic, so presumably some package or other is insisting it be held at 4.0.3~bionic. How do I see what package that is? I tried apt rdepends wine-stable-amd64 but the only package listed and installed that depends on it is...wine-stable! So what on earth is going on?
