121
I'm thinking about installing Ubuntu Desktop, but I don't know what flavor is the best for my system. What are the minimum and recommended hardware requirements? What kind of CPU? How much memory? Should I have Hardware Acceleration? What flavor should I use?
This is an attempt of a canonical answer. My answers have the "official requirements", the recommended are a mix of official sources and opinion based (along with the answer it's told the source). You can comment or edit if you feel that the information is obsolete or incomplete.
It is a good rule of thumb that any system capable of running Windows Vista, 7, 8, x86 (Intel) OS X will almost always be a lot faster with any Ubuntu flavor even if they are lower-spec than described below.
Braiam
  • 69,112
8 Answers8
59
Ubuntu Desktop
Ubuntu Desktop screenshot
Ubuntu returned to using the GNOME Shell with Ubuntu 17.10, so it's the only non-ESM desktop supported.
Recommended Minimums
  • Bionic Beaver (18.04) and later
    • at least 2 GHz 64-bit processor
    • at least 4 GB of system memory
    • at least 25 GB of free disk space Minimum 8.6 GB
    • other requirements may follow the "Recommended" section
    • VGA capable of 1024 x 768 screen resolution
    • 3D Acceleration capable GPU with at least 256 MB
Ubuntu has varying requirements on VM.
Bionic Beaver (18.04) on VM: Requires VT-x/AMD-V hardware acceleration. Requires at least 1156 MB RAM and 128 MB video memory, but disable 3D acceleration for at least usable desktop to open menu and change settings. This is the practical minimum for a test drive, but not for daily use.
Recommended
For latest recommended requirements, visit download page of Ubuntu Desktop.
Braiam
  • 69,112
28
Xubuntu
Recommended for Xubuntu 20.04 or later:
  • 2+ GiB of system memory (RAM) Minimum 512MB
  • 20+ GB of disk space Minimum 8GB
  • Graphics card and monitor capable of 1024x768 resolution
  • 1.5 Ghz dual Core processor
guiverc
  • 33,561
Braiam
  • 69,112
17
Kubuntu
Kubuntu desktop image
The official flavour of Ubuntu using KDE. The default desktop environment is KDE Plasma Desktop.
Minimum
  • Xenial Xerus (16.04)
    • 5 GB of free disk space
    • other requirements are similar to the following
    • 1 GHz processor
    • 512 MB of system memory (RAM)
    • 8 GB of free disk space
    • VGA capable of 1024x768 screen resolution
The minimum requirements were last mentioned in Kubuntu 8.04 news announcement, then merely copied from Ubuntu 12.04 release note and has since deprecated, and not found at elsewhere. The minimum requirements for newer release is unofficial and subject to testing on real hardware or in a virtual machine (VM). Kubuntu has varying requirements on VM.
Xenial Xerus (16.04) on VM: Requires at least 1 GB RAM, 10 GB fixed-size Virtual Disk Image, 128 MB video memory. Selecting "Try Kubuntu" or "Install Kubuntu" does not matter. Live session will takes time to load; If virtual machine has stopped responding, do reset and start again. Installation may take longer time. User will see "low disk space warning" during installation but will succeed.
Bionic Beaver (18.04) on VM: Requires VT-x/AMD-V hardware acceleration, regardless of 32-bit or 64-bit ISO image. Requires at least 9 GB fixed-size Virtual Disk Image. With 512 MB RAM, choose either "Try Kubuntu" or "Install Kubuntu"; otherwise, running the installer from desktop will not work as expected. With 768 MB RAM, user can first choose "Try Kubuntu" and later can also run the installer from the live desktop.
Recommended
  • 1 GHz dual core processor or better
  • 2 GB of system memory (RAM)
  • 10 GB of free disk space (the more hard disk capacity, the better)
  • VGA capable of 1024x768 screen resolution. If desktop effects are desired, a supported GPU is required.
The recommended requirement is based on this poorly cited source on Wikipedia and this partially compatible requirements for Ubuntu 16.04. The amount of system memory and free disk space are similar to the requirements for KDE neon.
Kubuntu has no official system requirements to this revised date.
Braiam
  • 69,112
Ubuntu Mate
Ubuntu Mate is a official flavour of Ubuntu, based on Mate DE. Designed to run on modern desktops and laptops, micro computers and older hardware alike.
Ubuntu Mate Image from Wikipedia
Hardware Requirements:
Minimum:
  • Pentium M 1.0 gigahertz
  • 1 gigabyte (GB) of RAM
  • 9 gigabytes (GB) of available space on the hard disk
  • Bootable DVD-ROM drive/USB flash drive
  • Keyboard and Mouse (or other pointing device)
  • Video adapter and monitor with 1024 x 768 or higher resolution
  • Sound card
  • Speakers or headphones
Recommended:
  • Core 2 Duo 1.6-gigahertz
  • 2 gigabytes (GB) RAM
  • 16 gigabytes (GB) of available space on the hard disk
  • Bootable USB flash drive
  • 3D capable video adapter and wide screen monitor with 1366 x 768 or higher resolution
  • Sound card
Reference:
blade19899
  • 26,994
Ubuntu Kylin
Ubuntu variant for Chinese users.
Minimum
  • Trusty Tahr (14.04)
    • 1 GHz processor (for example Intel Celeron or better)
    • 1 GiB RAM (system memory)
    • 8 GB of free hard drive space for installation
    • Either a CD/DVD drive or a USB port for the installer media
    • Internet access is helpful (for installing updates during the installation process).
  • Zesty Zapus (17.04)
Ubuntu Kylin daily build has 64-bit PC desktop image only and has noted that user will need at least 1024 MiB of RAM to install from the image.
Recommended
No official information found yet
Braiam
  • 69,112
Modern Lubuntu (using LXQt)
The Lubuntu team published Taking a New Direction
which states
our main focus is shifting from providing a distribution for old hardware to a functional yet modular distribution focused on getting out of the way and letting users use their computer.
with the following goals
  • Lubuntu will leverage modern, Qt-based technologies and programs to give users a functional yet modular experience.
  • In collaboration with others, Lubuntu will continue to be a transparent and open distribution which makes it a priority to keep the community informed about the development when possible.
  • Lubuntu will create and maintain complete documentation which will be included by default in the operating system, and can guide anyone from beginner to expert on how to use Lubuntu to its full potential and contribute to the further development of it.
  • Lubuntu will keep a light experience by default but enable users to utilize more heavy and featureful components as desired.
  • Lubuntu will have the ability to be used in any language across the world, and enable contributors to easily translate all components of the operating system.
meaning
This means that Lubuntu will stay light, and for users with old systems, should still be usable. But we will no longer provide minimum system requirements and we will no longer primarily focus on older hardware.
Devices with as little as 1GB of RAM were used in QA-testing Lubuntu up to and into the disco cycle (or Lubuntu 19.04), however devices used for QA-testing later releases contained 2GB or more of RAM.
Your requirements will vary on how you use your machine, especially application choice (ie. selecting software that uses the same libraries already used by your desktop means less RAM is required).
Lubuntu up to 18.04 used the LXDE desktop which used the GTK2 toolkit. The LXDE developers however felt GTK3 was too heavy, so had joined forces with the Razor-Qt developers creating a new LXQt desktop that would remain light and fully utilize Qt5.
Lubuntu doesn't use KF5 (KDE Frameworks 5) so whilst KDE apps will efficiently use Qt5 libs already used by the desktop, the hit to many KDE apps is the need to load KF5, which is still likely less than using an GTK3 app.
The right choice for you, will depend very much on what applications you use.
A recent Front Page Linux article wrote
"When we start to look at RAM utilization and hard disk space, the clear stand-out is Lubuntu"
however as already indicated, if you need specific GTK3 apps, Lubuntu may not be best for your use-case; only you can decide what's best for you; based on what you'll use your machine for.
guiverc
  • 33,561
Ubuntu Budgie (formerly Budgie-Remix)
The official flavour of Ubuntu using Budgie desktop environment, since 9 November 2016. 17.04 is the first official release under the new name, Ubuntu Budgie.
Minimum
The minimum specified hardware for flawless experience.
  • 1.5 GHz processor
  • 60 GB of disk space
In 90% of cases you are good to go with those and specs above. However, some machines have specific hardware that requires you to check the driver before installation which is usually related to Broadcom Network cards found in laptops.
Recommended
The recommended download details for 18.04 and newer:
  • 4GB or more of RAM
  • 64-bit capable Intel and AMD processors
  • UEFI PCs booting in CSM mode.
  • Modern Intel-based Apple Macs
See "Installation Guide" in download page of Ubuntu Budgie.
Regarding 32-bit x86 CPUs
As of October 2019 (Ubuntu version 19.10 and 20.04 LTS), the 32-bit x86 architecture is no longer officially supported in Ubuntu.
This means that if you still have a 32-bit CPU, the best option is to look for another Linux distribution that officially supports 32-bit x86 architecture.
To find out details about your CPU, visit the following links and search for your CPU model:
Artur Meinild
  • 31,035
