I want to buy a laptop, wipe it and install Ubuntu 14.x.x on it. I saw this HP Stream with this specs:
Celeron N3060 speed1.6 GHGz Graphics cardIntel GMA HD Ram 2 GB SSD 32 GB (eMMC)
Do you think I can Install Ubuntu 14 on this one? Im suspicious of the eMMC disk in particular.
Thank you all.
SkouP
Ubuntu will run perfectly fine on the Stream. 32 GB eMMC will be slightly tight, but will be faster than a standard 5400rpm hard disk. 2GB of RAM is also slightly tight, but shouldn't be a problem for normal use.
Edit: There were issues in the kernel concerning eMMC on the Stream. However, several people have successfully installed and the kernel issues have been fixed. See this link:
HP Stream 13-C004TU Notebook for Ubuntu Install
Edit2: There seems to be a few network issues concerning the Broadcom wireless card.
negusp
  • 2,831
I have x2 HP Stream 14 laptops running Antergos and they run beautifully. I imagine that ubuntu will run equally well.
In order to boot from usb I had to enter bios (f10 on startup), enable legacy mode in boot options, set usb as 1st boot.
I'm not sure on the install of ubuntu but I had to manually make partitions for the home,swap,ESP which I did with help from here:
https://antergos.com/wiki/install/how-to-dual-boot-antergos-windows-uefi-expanded-by-linuxhat/
I imagine Ubuntu might be a simpler install and should work fine, but I can vouch the Antergos runs like a dream!
