I have a 120 GB SSD and a 500 GB HDD .
In the SSD I have partitioned 98 GB (usable) as C: to start Windows and 19 GB as E: to start Ubuntu. In the HDD I have partitioned 350 GB as D: for Windows data and 116 GB as F: for Ubuntu data.
I have not yet attempted to install Ubuntu and want to ask, will this work?
Zanna
  • 72,312
Gerald
Ubuntu (and Linux in general) does not require particularly fast disk drive. I you are running memory-intensive applications or have small RAM in your comp you should put swap on SDD and all other Ubuntu filesystems on HDD.
In such case you should have at least 3 partitions available for your Ubuntu installations:
  • 1st for swap - preferably on SDD
  • 2nd for /boot
  • 3rd for everything else - I usually use it to create LVM volume so I can keep things separated while having some flexibility
Here is my favourite partitioning example:
Filesystem                      1K-blocks      Used Available Use% Mounted on
/dev/mapper/ubuntu--vg-root--lv  10190136   1775676   7873788  19% /
/dev/mapper/ubuntu--vg-usr--lv  103081248   6285284  91536700   7% /usr
/dev/mapper/ubuntu--vg-srv--lv     999320      1284    929224   1% /srv
/dev/sda2                          516024    368440    121372  76% /boot
/dev/mapper/ubuntu--vg-tmp--lv   10190136     23568   9625896   1% /tmp
/dev/mapper/ubuntu--vg-opt--lv   10190136    207132   9442332   3% /opt
/dev/mapper/ubuntu--vg-home--lv   2535216    643960   1761172  27% /home
/dev/mapper/ubuntu--vg-var--lv   20511356   1361992  18168300   7% /var
Please note /boot on a separate partition.
You can search for "Ubuntu custom partitioning" or review this question for reference: How to use manual partitioning during installation?
The proposed scheme has also the advantage, that if you remove HDD and move it to another PC you just loose swap, but Ubuntu stays usable - you can import volume group and mount filesystems or you even may be able to boot it up and use. (depending on hardware similarities)
Pawel Debski
  • 2,814
Yes, you can install Ubuntu in a logical partition, it is not required to install Ubuntu in a primary partition. Also the swap-partition (if you intend to use one) can reside in a logical partition.
mook765
  • 18,644
