I have a 13" Macbook Pro 2010. Should I download the 32-bit version or the 64-bit version of Ubuntu?
Asked
Active
Viewed 732 times
The way you work this out is by looking up what sort of CPU you have and then looking up that CPU to see what it supports. In your case:
64-bit should be fine. 32bit will also work.
Oli
- 299,380
According to Google, your MacBook has 4GB of RAM memory. The rule of thumb to use is that you should install the 64-bit version of Ubuntu if you have more than 3GB of RAM and if your CPU supports a 64-bit OS. Intel Core 2 Duo CPUs support 64-bit OSs, so you should choose the 64-bit version of Ubuntu.
karel
- 122,292
- 133
- 301
- 332
