My computer's specs are: System: Microsoft Windows XP Professional Version 2002 Service Pack 3
Computer: Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93 GHz 2.93 GHz, 1.99 Gb of RAM
If my computer can't run the current version of Ubuntu, are there older versions of Ubuntu can run on this PC?
Braiam
  • 69,112
Crackers
  • 39
That spec. is fine to run 32-bit Ubuntu.
I would recommend: 12.04.2 LTS
Download Ubuntu Desktop
You should 'try' first, with a USB or DVD start disk.
To be certain of full support, you also need to identify the graphics chip/card, and any other (unusual) devices or applications ..
david6
  • 14,528
  • 38
  • 46
That should be able to run Ubuntu 13.04. But if it doesn't, use one of the LTS releases. Like 10.04 (old, but works) or 12.04. They are very stable and are more likely to work. Hope this helps!
I think that it is fine... Ubuntu works fine on my laptop too with only 512 mb or RAM and 1.6 GHZ of CPU power. So your computer should be fine. Try it from a live USB. Base on your specs, you may able to run Ubuntu 13.04 well. Otherwise, use 12.04 like me.
Note, my PC does not have opengl 2.0 too. Unity still works well but slow.
user27731
  • 461
