I have a computer, below are the specs:
RAM: 1GB DDR2 Processor: Intel(R) Celeron(R) CPU 2.53GHz Network Adapter: Intel(R) PRO/100 VE Network Connection (Ethernet) 500GB IDE HDD
The computer is currently running Windows XP and is extremely slow, is switching to Ubuntu 12.04LTS a good idea (performance wise)?
Thank you :)
5 Answers5
Because of possible performance issues you should choose Xubuntu 12.04 32-bit. Xubuntu 12.04 is a Long Term Support release (LTS) that is supported by updates until April, 2015 (Update: the latest LTS release is 14.04). Lubuntu is also an option, but it does not yet have Long Term Support. However Lubuntu 14.04 will be an LTS release which will be supported by updates for three years until April, 2017.
karel
  • 122,292
  • 133
  • 301
  • 332
Yes, it is, but I would recommend you to choose lightweight window managers like lxde, openbox, xfce instead of gnome/kde/unity.
pondohva
  • 551
Looking at your specs you may not experience performance issues as in Ubuntu's official site states that; A good "rule of thumb" is that machines that could run XP, Vista, Windows 7 or x86 OS X will almost always be a lot faster with Ubuntu even if they are lower-spec than described in Recommended Minimum System Requirements.
Simply try Ubuntu CD as a LiveCD first to check the hardware works. In such case, I would recommend you to have a look at Ubuntu's official documentation about various distribution and its useful information.
AzkerM
  • 10,390
As my personal experience Ubuntu 12.04 LTS is heavier than windows XP. If you are having extremely slow conditions under XP then Ubuntu 12.04 would not be a good choice given that your computer configuration is also not quite sufficient for Ubuntu 12.04 specially the RAM;
As others said go for light versions like Lubuntu or Xubuntu;
hatef
  • 185
12.04 may run well in 2D mode (you can choose it at log in). I found that Ubuntu in 2D mode takes about the same amount of resources than Xubuntu, so try 2D first. If that doesn't run fast enough then Lubuntu is a good choice for the amount of RAM you have installed.
I expect your WinXP installation is running slow due to fragmentation issues, or various mal-ware finding it's way on your system. You might be able to reinstall XP and regain your speed, but it's end of life will give you more problems than switching your operating system.
