I have windows 7 installed in my laptop. I have a lenovo G570 series laptop. I would like to install ubuntu. Can anyone tell me which version to install ( 32-bit or 64-bit and 12.04 or 13.04)
64 bit should be fine on that, if you have the Intel® Core™ i5-2450M processor as the specs advertised for your machine say (64 bit instruction set). 12.04 is entirely stable and I have no issues with it, I use the gnome desktop with it. I have open questions on 13.04, so I don't necessarily recommend it unless you have hardware that isn't found with earlier releases (Newer machines) My Lenovo R61i runs 12.04, this is my main machine. My Toshiba Tecra runs dual-boot Ubuntu 13.04/Mint 14.1, I use that one to research with answering questions from people I install for, as I install both Ubuntu and Mint for friends, depending on what they want, and help them get started using it...
- 31
Well, you can install either one. I recommend that you install 13.04 64Bit. You can download it here. Once downloaded you can either create a bootable DVD or a USB flash drive. To create either on see the Install Ubuntu 13.04 website.
Once you create either of the above two options, just get your system to boot either from the DVD or The USB flash drive, and you're good to go.
If you so desire to check things out before actually installing, once you boot from either, just choose Try Ubuntu, and that will let you try it to see if it works with your hardware, and if you like it.
- 109,787
