I have a old Win XP Pro machine that I would like to install Ubuntu on and would like to know what is the best version to get as there are several releases available on Amazon, my go to store. Since this is a 2002 vintage machine I'm assuming one of the older releases is most likely to install without problems.
I built this machine in 2002. It is a 32-bit, Intel P4-D845EBG2L mother board with Pentium 4, 2.2GH, Northwood 512K, Socket 478, 400MHz bus, CPU. It has 1GB of memory, a ATI All-in-Wonder Radeon 8500DV, 64MB, DDR AGP-Retail, Video card. There are CD, DVD, Floppy and USB 2.0 drives.
My goal is to learn Linux with the Ubuntu release. I have very little knowledge of Linux but have worked with Windows since the DOS days and am some what comfortable at the DOS (windows) command prompt. I admit to drinking the Windows Kool-Aid.
Thanks for any assistance
Greid
greid
You can use Lubuntu (a fast and lightweight Linux operating system with low hardware requirements) 18.04 which is the last LTS to support 32-bit computers. Click here and select the 32bit image file for Lubuntu 18.04.5 LTS.
Note: 18.04 is only supported until April 2021 and is the last LTS version of Lubuntu that will have 32-bit support.
ldias
  • 2,135
Ubuntu 16.04 was the last LTS with 32 bit support, and it is end of life in 2021. Debian is probably a better bet than Ubuntu in this use case, as they still support 32 bit. If you are going to run a desktop, you will need to stick with something light, LXQT/LXDE or a plain window manager.
That all said, you would better served picking up an inexpensive Raspberry Pi. They are cheap and will perform better than what you have.
