-1
Ive tried 20.04 on a phenom x4 905e with 3gb pf ram. It passes all hardware tests. Tried dvd and thumbdrive installs. It goes to a black screen with white ubuntu at the bottom and a mouse pointer that moves but nothing else. Getting really frustrated as ubuntu 8,9, 10, 16 run fine on this machine.
david
  • 433
The 3GB of memory will certainly be an issue for Gnome-based desktops since 2018. Let's look at the hardware requirements over the years:
Release Minimum Recommended
8.04 (Hardy) 32 or 64-bit CPU / 384 MB RAM for the Desktop
9.04 (Jaunty) 32 or 64-bit CPU / 256 MB RAM for the Desktop
10.04 (Lucid) 32 or 64-bit CPU / 256 MB RAM for the Desktop
16.04 (Xenial) 1GHz 32 or 64-bit CPU / 1.5 GB RAM / 10 GB Storage
20.04 (Focal) 2 GHz 64-bit CPU / 4 GB RAM / 25 GB Storage
As you can see, the system requirements have evolved quite a bit along with the operating system itself. The AMD Phenom x4 905e does meet the requirements with its 2.5 GHz clock and 64-bit instruction set, but Gnome may be a bit too heavy for the system. As a result, you may want to try a lighter distribution such as Ubuntu MATE or Bodhi Linux. Both of these are pretty darn good alternatives.
matigo
  • 24,752
  • 50
  • 79
