I'm new here! I was wondering if my PC can run Ubuntu and I don't know how to check it... My system is: Processor: Intel(R) Core(TM) i3-2350M CPU @ 2.30GHz RAM: 4GB (2,70GB AVAILABLE) 32 BITS
Can somebody help me pleaseee?? Thankssss
Your configuration should be OK, as the recommended minimum requirements are:
  • 2 GHz dual core processor
  • 4 GiB RAM
To be safe, you should try first Ubuntu with a live CD. If you're convinced then you can install it on your laptop. If not, you may want to use a lightweight alternative, like Xubuntu or Lubuntu, which will definitely suitable to your config.
Likid
  • 126
