I'm currently running a Windows 7 machine, which is effectively acting as a server for my network. The plan is to ditch it and put Ubuntu server on it. I have some concerns though. One of which is a spanned array of disks I have on it. It's got 5x 3TB Hard Drives on there which are completely independant of the operating system (i.e. the OS was installed on a separate hard drive). I'm fairly new to Linux, so I am wondering how easy it would be to install a new hard drive with Ubuntu server on it, then attach these 5 drives onto that server without losing any data (is it possible)?
Next question. The kit I'm using is really old. So I have some concerns with wondering if my kit will be compatible. The spec of most of the hardware is below: CPU:Intel Core 2 Quad Q9450 LGA775 Motherboard: Asus P5Q-E HDD: 5x WD30EFRX RAM: Not sure, it's some DDR2 Kingston stuff, 4 sticks of it.
Should I just bin it & buy something new to make sure it will work?
john smith
  • 3,161
Nope. Windows uses "dynamic disks" for raid and spanning volumes, which is not supported in linux. Of course, if you aren't backing up your data already, it is only a matter of time until you lose it, so you should already have a backup method. With that, back up your data, and when you install ubuntu server you can format the drives as a linux raid, then restore your data.
psusi
  • 38,031
