I'm not sure what you want, but:
- The parent repository is always http://archive.ubuntu.com/ubuntu - everything else is a mirror of this. The other primary mirrors all have a domain of the form
<cctld>.archive.ubuntu.com, where the two character short code is the Country Code Top Level Domain. You can find additional mirrors with their status at Launchpad.
- If you're on an architecture other than
amd64 (e.e.g, arm64, armhf, ppc64el, etc.), then the parent repository is http://ports.ubuntu.com/ubuntu-ports. Use ports.ubuntu.com/ubuntu-ports instead of archive.ubuntu.com/ubuntu in everything that follows.
- The distribution codename is part of the channel (the third term). You can use
lsb_release -sc to find that out, and it's the first word of the release pretty name in lowercase (trusty for Trusty Tahr, for example).
- There are five channels:
<codename>, <codename>-security, <codename>-updates, <codename>-backports and <codename>-proposed. The first is necessary as it is the base, the second is highly recommended as it contains security fixes, the fourth only if you need some package backported from a newer release and the fifth only if a developer asks you to enable it for testing a possible fix.
- There are four repository sections:
main, multiverse, universe and restricted (What's the difference between multiverse, universe, restricted and main?)
So you can always create a safe sources.list which contains just:
deb http://archive.ubuntu.com/ubuntu <codename> main multiverse universe restricted
deb http://archive.ubuntu.com/ubuntu <codename>-security main multiverse universe restricted
If you want a command to do this:
printf 'deb http://archive.ubuntu.com/ubuntu %s main multiverse universe restricted\n' "$(lsb_release -sc)"{,-security} > /etc/apt/sources.list
Or, lsb_release isn't available, use /etc/os-release from the base-files package:
printf 'deb http://archive.ubuntu.com/ubuntu %s main multiverse universe restricted\n' "$(. /etc/os-release; printf "%s" "$UBUNTU_CODENAME")"{,-security} > /etc/apt/sources.list
In addition to the Launchpad list, the list provided by the Software Sources program is
from /usr/share/python-apt/templates/Ubuntu.mirrors, which is from the python-apt-common package. This package is only an indirect Suggests dependency of apt, so it may not be installed by default on a server.
