I've badly damaged my package system. So I found another solution,
sudo apt-get build-dep <package>
But when I typed sudo apt-get build-dep update-manager, I got,
E: You must put some 'source' URIs in your sources.list
Then I accessed it using the sudo nano /etc/apt/sources.list. The list was blank. Now I'm unsure on how to add more source URIs. I cannot access the software updater to change it. I've tried Synaptic Package Manager.
sudo apt-get -f install
Reading package lists... Done
Building dependency tree
E: The package python3 needs to be reinstalled, but I can't find an archive for it.
Update:
I have edited sources.list using @karel's answer on What is the correct output of cat /etc/apt/sources.list? and replacing bionic with cosmic.
Now when I try to launch software-properties-gtk, I'm getting:
bash: /usr/bin/software-properties-gtk: /usr/bin/python3: bad interpreter: Too many levels of symbolic links
Outputs for symbolic links of python3:
$ ls -l /usr/bin/python3
lrwxrwxrwx 1 root root 18 May 27 20:30 /usr/bin/python3 -> /usr/bin/python3.6
$ ls -l /usr/bin/python3.6
lrwxrwxrwx 1 root root 25 May 27 16:31 /usr/bin/python3.6 -> /etc/alternatives/python3
$ ls -l /etc/alternatives/python3
lrwxrwxrwx 1 root root 18 May 27 16:31 /etc/alternatives/python3 -> /usr/bin/python3.6
Output of ls -l /usr/bin/python*:
lrwxrwxrwx 1 root root 18 May 27 23:10 /usr/bin/python -> /usr/bin/python3.2
lrwxrwxrwx 1 root root 9 Jun 7 2018 /usr/bin/python2 -> python2.7
-rwxr-xr-x 1 root root 3691008 Apr 9 05:50 /usr/bin/python2.7
lrwxrwxrwx 1 root root 33 Apr 9 05:59 /usr/bin/python3.6-config -> x86_64-linux-gnu-python3.6-config
-rwxr-xr-x 1 root root 4530552 Apr 9 05:59 /usr/bin/python3.6m
lrwxrwxrwx 1 root root 34 Apr 9 05:59 /usr/bin/python3.6m-config -> x86_64-linux-gnu-python3.6m-config
-rwxr-xr-x 2 root root 4804160 Apr 9 05:56 /usr/bin/python3.7
-rwxr-xr-x 2 root root 4804160 Apr 9 05:56 /usr/bin/python3.7m
lrwxrwxrwx 1 root root 16 Oct 25 2018 /usr/bin/python3-config -> python3.6-config
lrwxrwxrwx 1 root root 10 Oct 25 2018 /usr/bin/python3m -> python3.6m
lrwxrwxrwx 1 root root 17 Oct 25 2018 /usr/bin/python3m-config -> python3.6m-config
