I changed my default Ubuntu source list to change the dist name to be xenial instead of artful since support is gone.
I ran:
$ sudo apt-get update
$ sudo apt-get dist-upgrade
$ sudo apt-get autoremove
And it updated with success all (except rabbitmq/nvidia/wireless-regdb) my packages.
My issue is that now a lot of my packages are broken and I can't install without fixing the issues.
Error below:
❆ ~/ ➭ sudo apt-get install libdbus-1-dev libdbus-glib-1-dev
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
libdbus-1-dev : Depends: libdbus-1-3 (= 1.10.6-1ubuntu3.5) but 1.10.22-1ubuntu1 is to be installed
libdbus-glib-1-dev : Depends: libdbus-glib-1-2 (= 0.106-1) but 0.108-2 is to be installed
❆ ~/ ➭ sudo apt-get install python3-pil.imagetk
python3-pil.imagetk : Depends: python3-pil (= 3.1.2-0ubuntu1.1) but 4.1.1-3build2 is to be installed
Depends: python3 (< 3.6) but 3.6.3-0ubuntu3 is to be installed
I have tried
$ sudo apt-get clear cache
$ sudo apt-get install --reinstall <broken package>
$ sudo apt-get install --fix-broken
Without success.
Do I need to apt-get purge <broken package>? It saying it will remove a lot of vital packages and it scares me a bit when trying to do so on python3 for example
