hii i try to setup lets encrypt i follow this tutorial (this is done by digital ocesn)
i tri this command
sudo apt install python-certbot-nginx
i get this out put
sudo: unable to resolve host ip-172-31-23-194: Resource temporarily unavailable
Reading package lists... Done
Building dependency tree
 python-certbot-nginx : Depends: python3-certbot-nginx but it is not going to be installed
and i get this error tooo
WARNING:root:could not open file '/etc/apt/sources.list'
i check this location '/etc/apt/sources.list'its have empty
note:i update 16.04-->1804 update use do release command
GHOST
  • 357
i already have python 2.7 that why its happen :) then i install python 3.0 and try its will install
GHOST
  • 357
