I have tried this: sudo apt install nodejs
Getting Error this:
Reading package lists... Done
Building dependency tree
 nodejs : Depends: python-minimal but it is not going to be installed
Gryu
  • 8,002
  • 37
  • 53
Make sure your /etc/apt/sources.list file is correct.
Run the next command to find out what release version you use:
cat /etc/lsb-release | grep RELEASE
Then follow one of the next links to change your /etc/apt/sources.list file:
19.10 sources.list
18.04 sources.list
16.04 sources.list
You could backup your old sources.list file by sudo mv /etc/apt/sources.list /etc/apt/sources.list.bk and create new one pasting there content from one of the provided links.
Then do
sudo apt clean && sudo apt update && sudo apt install npm nodejs node-abbrev node-ansi node-rimraf
and try again.
Also make sure there's no suspicious repositories under /etc/apt/sources.list.d/ folder that could also contain nodejs of newer version that do not contain required dependencies.
Gryu
  • 8,002
  • 37
  • 53
