I have installed Ubuntu 16.04 in April, but since I have barely received any system updates (the ones popping up automatically with the Software Updater). When checking the kernel version with uname -r I get 4.4.0-21-generic which according to this list here seems pretty out of date.
By trying to run an update manually with apt upgrade and apt update I receive:
sudo apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
  hostapd
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
sudo apt update
Hit:1 http://ftp.lysator.liu.se/ubuntu xenial InRelease
Ign:2 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:3 http://dl.google.com/linux/chrome/deb stable Release
Hit:4 http://archive.canonical.com/ubuntu xenial InRelease
Hit:5 http://ppa.launchpad.net/nilarimogard/webupd8/ubuntu xenial InRelease
1 package can be upgraded. Run 'apt list --upgradable' to see it.
sudo apt list --upgradable
Listing... Done
hostapd/xenial 1:2.4-0ubuntu6 amd64 [upgradable from: 1:1.0-3ubuntu2.1]
N: There is 1 additional version. Please use the '-a' switch to see it
Are there really any updates to install or is my system not finding them anymore?
wasp256
  • 837
You have quite a serious problem. The only official update server on your system seems to be the archive.canonical.com. All other servers listed above have been placed there manually after the inital system installation.
The missing update server's name should be <country-code>.archive.ubuntu.com (for example us.archive.ubuntu.com) and it's not there.
You can try reconstructing /etc/apt/sources.list by following the instructions here for example or you can re-install your system. There are several other places all over the internet where you can find similar instructions on how to reconstruct sources.list.
Stormlord
  • 6,807
I Was looking for this and here is the solution.
sudo apt full-upgrade
I'm on POP Os.
Stalyn
Repositories not configured
Your Ubuntu repositories are not configured correctly.
  1. Add some repository executing the command below:
    sudo apt-add-repository "deb http://archive.ubuntu.com/ubuntu xenial-updates main restricted"
  2. Now, try updating:
    sudo apt-get update
  3. Upgrade:
    sudo apt-get upgrade
amc
  • 7,292
