322
I want to be able to login to a remote via ssh without having to enter the password all the time.
  • How do I set it up?
  • Is a different command required to execute a password-less session?
Oxwivi
  • 18,499
10 Answers10
355
Answer
Execute this command (if you already have an SSH key, you can skip this step):
ssh-keygen
Then you'll need to copy the new key to your server:
ssh-copy-id user@host
## or if your server uses custom port no:
ssh-copy-id "user@host -p 1234"
After the key is copied, ssh into the machine as normal:
ssh user@host
You can now login without entering a password from the particular machine you executed the commands at.
Example
not-marco@rinzwind-desktop:~$ ssh-keygen
Generating public/private rsa key pair.
Enter file in which to save the key (/home/not-marco/.ssh/id_rsa):
Created directory '/home/not-marco/.ssh'.
Enter passphrase (empty for no passphrase):
Enter same passphrase again:
Your identification has been saved in /home/not-marco/.ssh/id_rsa.
Your public key has been saved in /home/not-marco/.ssh/id_rsa.pub.
The key fingerprint is:
b1:25:04:21:1a:38:73:38:3c:e9:e4:5b:81:e9:ac:0f not-marco@rinzwind-desktop
The key's randomart image is:
+--[ RSA 2048]----+
|.o= . oo.        |
|*B.+ . .         |
|*=o .   o .      |
|. o     S        |
|E.               |
| o               |
not-marco@rinzwind-desktop:~$ ssh-copy-id not-marco@server not-marco@server's password: Now try logging into the machine, with "ssh 'not-marco@server'", and check in:
~/.ssh/authorized_keys
to make sure we haven't added extra keys that you weren't expecting.
Explanation
This assumes you already can successfully connect to your server via SSH.
You'll need to generate an SSH Keypair which will allow you to identify you as yourself without using a password. You can opt to protect keys with a passcode if you wish, but this can be left blank allowing totally password-less SSH access.
  1. First create your SSH Keypair by running ssh-keygen this will create an id_rsa and id_rsa.pub file. The pub file is what goes on the servers, the private key (id_rsa) is what stays with you and is how you identify yourself.
  2. Next copy the public key to your server with ssh-copy-id user@server replacing user with your remote user and server with the machine DNS name or IP address. It'll prompt for your SSH password, enter it and if all completes successfully you'll be able to access the machine via ssh user@server without needing a password.
References
Rinzwind
  • 309,379
47
Type the following commands:
  1. ssh-keygen
    Press Enter key till you get the prompt
  2. ssh-copy-id -i root@ip_address
    (It will once ask for the password of the host system)
  3. ssh root@ip_address
Now you should be able to login without any password.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Ravindra
  • 571
30
The way I usually do this is as follows:
ssh-keygen -t rsa
(When prompted for a password, leave it blank)
Then: cat ~/.ssh/id_rsa.pub | ssh username@hostname 'cat >> .ssh/authorized_keys'
(This requires the folder .ssh to be in the home directory on the targeted hostname, with the authorized_keys file in it)
Of course, replace username with the desired username, and hostname with the desired hostname or IP address
After that, just SSH to that box just like you're used to.
kyentei
  • 301
20
I normally use sshpass for that, install it with sudo apt-get install sshpass and use it like this
sshpass -p 'password' ssh your_username@your_server
Bruno Pereira
  • 74,715
13
Disable Password Authentication
Because a lot of people with SSH servers use weak passwords, many online attackers will look for an SSH server, then start guessing passwords at random. An attacker can try thousands of passwords in an hour, and guess even the strongest password given enough time. The recommended solution is to use SSH keys instead of passwords. To be as hard to guess as a normal SSH key, a password would have to contain 634 random letters and numbers. If you'll always be able to log in to your computer with an SSH key, you should disable password authentication altogether.
If you disable password authentication, it will only be possible to connect from computers you have specifically approved. This massively improves your security, but makes it impossible for you to connect to your own computer from a friend's PC without pre-approving the PC, or from your own laptop when you accidentally delete your key.
It's recommended to disable password authentication unless you have a specific reason not to.
To disable password authentication, look for the following line in your sshd_config file:
#PasswordAuthentication yes
replace it with a line that looks like this:
PasswordAuthentication no
Once you have saved the file and restarted your SSH server, you shouldn't even be asked for a password when you log in.
https://help.ubuntu.com/community/SSH/OpenSSH/Configuring#disable-password-authentication
muru
  • 207,228
Thufir
  • 4,631
10
This solution is specifically for users using Windows to ssh into their remote machines including cloud images on AWS Cloud and GCE Cloud
Disclaimer
Recently used this solution to remote login new deployed vm images on GCE.
Tools used:
  1. puttygen puttygen download
  2. winscp winscp download
Steps to perform:
  1. Generate public/private key pair using puttygen.
  2. Upload public key to your server in cloud or remote location.
How to do it:
1. Generate a key/pair or use existing private key
If you own a private key:
Open puttygen, press load button and select your private key (*.pem) file.
If you do not own a private key:
  • Open puttygen,
  • Select the desired key type SSH2 DSA (you may use RSA or DSA) within the Parameters section. It is important that you leave the passphrase field blank.
  • Press generate and follow instructions to generate (public/private) key pair.
Sample Key Generation pic
(from source 1, link given below)
2. Create a new 'authorized_keys' file (with notepad)
Copy your public key data from the "Public key for pasting into OpenSSH authorized_keys file" section of the PuTTY Key Generator, and paste the key data to the authorized_keys file.
Make sure there is only one line of text in this file.
3. Upload key to the Linux server
  • Open WinSCP,
  • Select SFTP file protocol and login with your ssh credentials.
  • On success, you see home directory structure at your remote machine.
Upload authorized_keys file to home directory at remote machine.
4. Set proper permissions
Make .ssh directory (if not existing)
Copy authorized_keys file to .ssh directory.
(this will replace any existed authorized_keys file, take note of this).
If file existed, simply add contents of this file to the existing file.
Run commands to set permissions:
sudo chmod 700 .ssh && chmod 600 .ssh/authorized_keys
Now You will be able to ssh into remote machine without entering credentials every time.
Further reading:
If you create a public/pricate keypair and log in using our newly created public key, you will not need to type your password. Depending on the configuration of your key-ring and/or ssh agent you might need to protect your key with a passphrase.
Here is one of many short howtos for you. It is of crucial importance to the safety of this method, that the generated private key remains private! You should never share it with anyone or allow access of it in any capacity.
This command generates a reasonably strong key in ~/.ssh/:
ssh-keygen -b 4096
In ~/.ssh/ you will find your public key as id_rsa.pub. Its contents should be appended to your servers authorized_keys file by transporting the via a transportable media (pen drive) or by shortly enabling password authentication on the server, then using ssh-copy-id ~/.ssh/id_rsa.pub username@server and then disabling it again.
If you chose to secure your key with a passphrase (in the first step), you can use ssh-agent or the Ubuntu keyring to secure that pharse locally so you don't have to type it all the time.
con-f-use
  • 19,041
To make some additions:
  • Mac by default doesn't have ssh-copy-id, you'll have to install it youself:
    curl https://raw.github.com/beautifulcode/ssh-copy-id-for-OSX/master/ssh-copy-id.sh -o /usr/local/bin/ssh-copy-id
    chmod +x /usr/local/bin/ssh-copy-id
find more here: https://github.com/beautifulcode/ssh-copy-id-for-OSX
  • if you've made a port-forwarding, the command should be like this:
    ssh-copy-id "not-marco@127.0.0.1 -p 2222"
note that the quotes are necessary.
Remote login/copy without giving a password
The applications ssh and scp for remote login and remote copy, respectively, allow you to communicate with a remote host without giving a password. This requires that you follow an authentication procedure like the one described below. By client we mean the machine your are sitting on and by server we mean the machine you want to log onto without giving a password. The steps of the authentication procedure are:
  1. Run ssh-keygen to generate private and public keys, unless this is already done on your machine. These are stored in files in $HOME/.ssh.
  2. Append the contents of the public key file to the file $HOME/.ssh/authorized_keys or $HOME/.ssh/authorized_keys2 on the server.
There are three different types of authentication protocols. You specify the type when running ssh-keygen:
  1. SSH protocol version 1, RSA1: this is the default choice and results in files identity (private key, should take chmod 0700 to ensure that this file is not readable for others) and identity.pub (public key).
  2. SSH protocol version 1, RSA: this is obtained by running ssh-keygen -t rsa and results in files id_rsa (private key) and id_rsa.pub (public key)
  3. SSH protocol version 1, DSA: this is obtained by running ssh-keygen -t dsa and results in files id_dsa (private key) and id_dsa.pub (public key)
When running ssh-keygen you can rely on default answers (implying that you do not give a passphrase). This makes the whole set-up simple, but also insecure.
You can specify the type of keys to be used by an option to ssh; ssh -1 forces use of RSA1 keys (protocol version 1), whereas ssh -2 forces ssh to try RSA or DSA keys only (protocol version 2). In the examples below, we generate and install RSA1 and DSA keys on the remote host such that you have more flexibility. You can make a config file in your .ssh directory with the line
Protocol 1,2
This makes ssh try an RSA1 (protocol version 1) connection before RSA/DSA (protocol version 2).
Using RSA1 keys
remote=user@remotehost   # fill in correct user and remotehost names
cd $HOME/.ssh
# create .ssh on remote host if it is non-existing:
ssh $remote 'if [ ! -d .ssh ]; then mkdir .ssh; fi'
# copy RSA1 key:
scp identity.pub ${remote}:.ssh
ssh $remote "cd .ssh; cat identity.pub >> authorized_keys"
Using DSA keys
cd $HOME/.ssh
# copy DSA key:
scp id_dsa.pub ${remote}:.ssh
ssh $remote "cd .ssh; cat id_dsa.pub >> authorized_keys2"
This is all you have to do if you did not use a passphrase when generating the keys. You can test the connection by running ssh $remote and see if you can log in without giving a password (you may need to use -1 or -2 as options to ssh). The procedure can, of course, be repeated for any machine you want to log onto.
If you did use a passphrase, you will have to run the program ssh-agent to start a special shell, followed by ssh-add to register your key/passphrase combination with sshd. See the man pages for these programs for more information.
A script for automating password-free connections: ssh-no-password.sh
#!/bin/sh
# create ssh connections without giving a password
if [ $# -lt 1 ]; then
  echo Usage: $0 username@remotehost
  exit
fi
remote="$1"  # 1st command-line argument is the user@remotehost address
this=$HOST   # name of client host
# first check if we need to run ssh-keygen for generating
# $HOME/.ssh with public and private keys:
if [ ! -d $HOME/.ssh ]; then
  echo "just type RETURN for each question:" # no passphrase - unsecure!!
  # generate RSA1, RSA and DSA keys:
  echo; echo; echo
  ssh-keygen
  echo; echo; echo
  ssh-keygen -t rsa
  echo; echo; echo
  ssh-keygen -t dsa
else
  # we have $HOME/.ssh, but check that we have all types of
  # keys (RSA1, RSA, DSA):
  if [ ! -f $HOME/.ssh/identity ]; then
     # generate RSA1 keys:
     ssh-keygen
  fi
  if [ ! -f $HOME/.ssh/id_rsa ]; then
     # generate RSA keys:
     ssh-keygen -t rsa
  fi
     # generate DSA keys:
     ssh-keygen -t dsa
  fi
fi
cd $HOME/.ssh
if [ ! -f config ]; then
  # make ssh try ssh -1 (RSA1 keys) first and then ssh -2 (DSA keys)
  echo "Protocol 1,2" > config
fi
# copy public keys (all three types) to the destination host:
echo; echo; echo
# create .ssh on remote host if it's not there:
# copy RSA1 key:
scp identity.pub ${remote}:.ssh/${this}_rsa1.pub
# copy RSA key:
#scp id_rsa.pub ${remote}:.ssh/${this}_rsa.pub
# copy DSA key:
scp id_dsa.pub ${remote}:.ssh/${this}_dsa.pub
# make authorized_keys(2) files on remote host:
echo; echo; echo
# this one copies all three keys:
#ssh $remote "cd .ssh; touch authorized_keys authorized_keys2; cat ${this}_rsa1.pub >> authorized_keys; cat ${this}_rsa.pub >> authorized_keys2; cat ${this}_dsa.pub >> authorized_keys2;"
# this one copies RSA1 and DSA keys:
ssh $remote "cd .ssh; touch authorized_keys authorized_keys2; cat ${this}_rsa1.pub >> authorized_keys; cat ${this}_dsa.pub >> authorized_keys2;"
echo; echo; echo
echo "try an ssh $remote"
copied from: http://folk.uio.no/hpl/scripting/doc/ssh-no-password.html
αғsнιη
  • 36,350
I'd like to add an answer for those who may find they should enter the password even they have read all answers here because you have set IdentitiesOnly as yes. And the answer here can save you much time to manage multiple keys, being keys for git or server.
After I have generated the key and copied it to the server:
ssh-keygen  # change the file to /home/yourname/.ssh/something
ssh-copy-id -i ~/.ssh/something.pub lerner@192.168.20.160
I found it didn't work.
Then I went to check the ~/.ssh/config file on the client, I saw this at the bottom:
Host *
IdentitiesOnly yes
Then I add this above:
Host somename
HostName 192.168.20.160
User lerner
IdentityFile ~/.ssh/something
I can just log in by entering ssh somename.
Then you can add multiple ssh keys using your favorite names, and you only need to add the settings like the above four lines to the config file.
Host is the name you'd like to enter when you connect the server later; the HostName is the server's ip; User is the user name you log in the server; and the identityfile is the file where you store the key you have generated.
Lerner Zhang
  • 271
