14
I have at this time two remote machines to which I am connecting. For one I am using private key with passphrase, and another one I am using root password.
Now, when I want to connect to machine with root password authentication, first ssh asks me for passphrase for machine which private key is inside my ~/.ssh directory,and then when I enter correct passphrase let me enter password for machine to which I am connectign with root password.
Is there any way to save sessions, and connection options, for example like in Putty?
Alan Kis
  • 267
You can use a per-user ssh-config file located in
~/.ssh/config
or a system-global one in
/etc/ssh/ssh_config
that stores the basic settings for each connection.
Example:
Host example_host
    User foo
    HostName example.com
    IdentityFile ~/.ssh/foo.key
    Port 23421
Having this in place, calling
ssh example_host
will open up a ssh-connection to example.com on port 23421, using the user foo and foo.key for authentication.
For an in-deep explanation, see the man page of ssh:
man ssh
Don't forget to set proper permissions on the config file:
chmod 600 ~/.ssh/config
hecke
  • 446
There is ~/.ssh/config as pointed out in the manual pages for ssh. It is well described there and in man ssh_config and also many times answered on askubuntu.
TL;DR:
# to preserve connections:
ControlMaster auto
ControlPath ~/.ssh/controlmasters/%r@%h:%p
ControlPersist 20m
# to provide correct keys, users, IPs and use aliases
Host yourHost
  Hostname IPaddress
  User user1
  IdentityFile ~/.ssh/id_ecdsa
Host yourSecondHost
  Hostname IP2
  User user2
  IdentityFile ~/.ssh/id_rsa
If you don't want to write passphrases, there is ssh-agent, where you can add the keys for your session:
eval `ssh-agent`
ssh-add ~/.ssh/id_ecdsa
# insert passphrase once
ssh yourHost
# will ask only for password
# next ssh connections will not ask for
Jakuje
  • 6,793
