20
As part of a startup script I have to automatically open several gnome-terminal windows, one of those terminals automatically send:
ssh user@192.168.1.3
The limitation with this is that I still need to type a password to complete the SSH connection.
What I want to do is for my script to initiate the command and complete the connection. To that extent, I attempted to follow the instructions as outlined in the accepted answer here.
From the system I wish to connect from, I ran:
ssh-keygen
Enter file in which to save the key: /home/user/ssh/keys/server1key
It then prompted me to enter a passphrase. I left this empty, as I wasn't sure what it would be for, so I assumed setting one would require unlocking it with said passphrase each time I'd use it.
Continuing with the instructions linked above, I then ran and received the following:
ssh-copy-id user@IP
ERROR: No identities found
A quick search revealed that I needed to specify the location of the key, as it was not in the default save location, so I fixed that:
ssh-copy-id -i /home/user/ssh/keys/server1key.pub user@192.168.1.3
After asking for the server's password, it successfully added the key. However, upon attempting to log in with "ssh user@IP", I was still prompted for the password.
As far as I'm aware, I followed the linked instructions correctly, so either I'm missing something, or perhaps an existing configuration is preventing me for getting this to work?
Both systems use 18.04 and openssh.
muru
  • 207,228
hiigaran
  • 6,843
It fails for the same reason that ssh-copy-id failed the first time - i.e. because you have chosen a non-default location for the identity file.
You can resolve it in the same way, by adding -i /home/user/ssh/keys/server1key to your ssh command - note that the client side needs the location of the private key file.
From man ssh
 -i identity_file
         Selects a file from which the identity (private key) for public
         key authentication is read.  The default is ~/.ssh/identity for
         protocol version 1, and ~/.ssh/id_dsa, ~/.ssh/id_ecdsa,
         ~/.ssh/id_ed25519 and ~/.ssh/id_rsa for protocol version 2.
Alternatively, you may wish to create a ~/.ssh/config file entry for the host along the lines of
Host            somename
Hostname        192.168.1.3
User            user
IdentityFile    /home/user/ssh/keys/server1key
steeldriver
  • 142,475
Another reason that ssh-copy-id fails is that the key hasn't been added to the SSH agent.
First, check and start if ssh-agent is running:
eval "$(ssh-agent -s)"
If you get in process ID, you can add your key:
ssh-add -k /home/user/ssh/keys/server1key
With -k you add the key to the keychain.
Check if keys are added with:
ssh-add -l
ssh-copy-id should be working now.
Eliah Kagan
  • 119,640
Martijn
  • 31
-1
Hope this will work for you.. "sshpass -p yourpassword" it will automatically login to remote host.
[root@localhost .ssh]# sshpass -p password123 ssh -l root localhost
JackyChan
  • 320
-1
Just execute 2 commands:
ssh-keygen
ssh-copy-id
Long answer:
user@ip:~$ ssh-keygen
Generating public/private rsa key pair.
Enter file in which to save the key (/home/user/.ssh/id_rsa): temp_file
Enter passphrase (empty for no passphrase):
Enter same passphrase again:
Your identification has been saved in stemp.
Your public key has been saved in stemp.pub.
The key fingerprint is:
SHA256:5**M user@ip
The key's randomart image is:
+---[RSA 2048]----+
| ..+.    o .     |
|    B            |
|=+   o .         |
+----[SHA256]-----+
And then:
user@ip:~$ ssh-copy-id -i ~/.ssh/id_rsa.pub ipDestination -p portDest
