Can we set up Passwordless SSH in Ubuntu (18.04) without root privileges? Is there any way to access files in /etc directory without root permissions? (I need to be able to set up Passwordless SSH between non-root users from between a local and remote system, but I don't have the root privileges on either system)
Asked
Active
Viewed 1,145 times
If your ssh server already has the publickey authentication method enabled, all you need to do is to append your own public key to the .ssh/authorized_keys file in the home directory of your server user. No further administrative configuration required for that.
And configuration files in /etc are normally all owned by the root user and not writable by anyone else, you can not bypass that as regular user without sudo. Otherwise that would be a security threat.
Byte Commander
- 110,243
