I know this question might have been asked before But I still cannot really find the answer, and the answer in my case should be simple.
So what have I done is in my ECS server I created a new user and gave it sudo privilege by assigning it to the sudo group. Then I change some of the sshd_config parameter:
  1. change port from 22 to another
  2. PermitRootLogin from "yes" to "no"
  3. PasswordAuthentication from "yes" to "no"
And then I generate SSH key by ssh-keygen -t rsa and copy it to the authorized_keys by ssh-copy-id user@ipAddress
and then I restart the server, ssh login to the server and get the Permission denied (publickey) error.
In the server /home/user/.ssh folder lies authorized_keys, id_rsa.pub and id_rsa three files. But in my local machine .ssh folder there is no key file.
So where is the problem?
Frostless
  • 143
Detailed instructions how to connect to SSH server can be found here
From your question it is clear that you should do the following:
How To Create SSH Keys
SSH keys should be generated on the computer you wish to log in from. This is usually your local computer.
Enter the following into the command line:
ssh-keygen -t rsa
Press enter to accept the defaults. Your keys will be created at ~/.ssh/id_rsa.pub and ~/.ssh/id_rsa.
have the following files in the ~/.ssh directory in the client machine:
-rw------- 1 demo demo 1679 Sep  9 23:13 id_rsa
-rw-r--r-- 1 demo demo  396 Sep  9 23:13 id_rsa.pub
As you can see, the id_rsa file is readable and writable only to the owner. This is how it should be to keep it secret.
The id_rsa.pub file, however, can be shared and has permissions appropriate for this activity.
On the server side, you should have the public key (not the private key).
Yaron
  • 13,453
