46
Possible Duplicate:
How can I set up password-less SSH login?
I am using ssh to connect to a remote server. I am prompted to provide a password each time, but I recall being able to set up a sort of authentication key, so that passwords were not required.
However, it has been ages, and I have forgotten just about everything about it, except the word "key". One of those things you set up and forget, and I never quite understood it to begin with.
How is it done?
TLP
  • 3,341
The answer you are looking for is here. Following is the excerpt from it :
Run the following command to create an SSH key pair. You can leave the passphrase blank if you do not wish to "unlock" your key each time you use it:
ssh-keygen -t rsa
The output will be similar to this
Generating public/private rsa key pair.
Enter file in which to save the key (/home/a/.ssh/id_rsa):
Created directory '/home/a/.ssh'.
Enter passphrase (empty for no passphrase):
Enter same passphrase again:
Your identification has been saved in /home/a/.ssh/id_rsa.
Your public key has been saved in /home/a/.ssh/id_rsa.pub.
The key fingerprint is:
3e:4f:05:79:3a:9f:96:7c:3b:ad:e9:58:37:bc:37:e4 a@A
Then you'll need to copy the new key to your server.
After copying the SSH keys you can log into your machine without a password.
