My current set up is:
  • I have my main machine (Darkseid) upstairs which has a drive with all my films on it, which I don't keep mounted.
  • Downstairs, next to the tv, I have a htpc (Archangel) which has xbmc installed on it, which points to a samba share on the main machine.
Everything works fine when the drive is mounted, but is there a script I can write to send a command to the upstairs machine from the downstairs machine to mount the drive to save the walk upstairs? #lazy
Both machines are Ubuntu 12.04
The way to do this would be to establish a remote connection to your server upstairs by using SSH.
By this you are able to remotely mount or unmount drives and you can even mount a remote directory on your local mythubuntu machine.
Related questions:
Takkat
  • 144,580
Not a script, but you can do something on boot for your machine, I did this on my server this morning, nothing wrong with a bit of laziness :)
AutomaticallyMountPartitions
Once you have worked out the terminal command to mount the drive;
  • Open Start-up applications (search start-up in dash/click top right > Start-up Applications)
  • Click Add
  • Name is Whatever you want
  • Command is the command you used in terminal (CTRL SHIFT C to copy)
