156
I tried to use xrandr to set 1680x1050 as a new mode to VGA output, but it says:
sudo xrandr --addmode VGA-0 1680
X Error of failed request:  BadMatch (invalid parameter attributes)
Major opcode of failed request:  140 (RANDR)
Minor opcode of failed request:  18 (RRAddOutputMode)
Serial number of failed request:  35
Current serial number in output stream:  36
Dagelf
  • 1,476
user216356
  • 1,561
6 Answers6
241
First generate a "modeline" by using cvt
Syntax is: cvt width height refreshrate
cvt 1680 1050 60
this gives you:
# 1680x1050 59.95 Hz (CVT 1.76MA) hsync: 65.29 kHz; pclk: 146.25 MHz
Modeline "1680x1050_60.00"  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync
Now tell this to xrandr:
xrandr --newmode "1680x1050_60.00"  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync
Then you can now add it to the table of possible resolutions of an output of your choice:
xrandr --addmode VGA-0 1680x1050_60.00
The changes are lost after reboot, to set up the resolution persistently, create the file ~/.xprofile with the content:
#!/bin/sh
You need to replace VGA-0 with your monitor connection. Use xrandr --listmonitors.
Elder Geek
  • 36,752
thom
  • 7,742
25
How to set a custom resolution previously specified. After executing the other steps defined to create the resolution, run:
xrandr -s 1680x1050
GuiRitter
  • 351
15
Thanks to thom and thirdender this is basically a single command configuration based on the most voted answer.
RES="1920 1200 60" && \
DISP=$(xrandr | grep -e " connected [^(]" | sed -e "s/\([A-Z0-9]\+\) connected.*/\1/") && \
MODELINE=$(cvt $(echo $RES) | grep -e "Modeline [^(]" | sed -r 's/.*Modeline (.*)/\1/') && \
MODERES=$(echo $MODELINE | grep -o -P '(?<=").*(?=")') && \
cat > ~/.xprofile << _EOF
#!/bin/sh
xrandr --newmode $MODELINE
xrandr --addmode $DISP $MODERES
_EOF
The above command will generate the desired ~/.xprofile file. Just make sure you use the resolution (i.e. the RES variable) of your liking. More info here.
You could replace
with
xrandr | grep -e " connected [^(]" | cut -d\  -f1
in $DISP variable if that does not work for you.
Gryu
  • 8,002
  • 37
  • 53
Tanasis
  • 516
14
How to set a custom resolution previously specified when running multiple monitors. After executing the other steps defined to create the resolution, run:
xrandr --output DVI-0 --mode 1680x1050
Replace DVI-0 with your device-id, e.g. VGA-0
zwessels
  • 267
Definitely you have to take a look at autorandr, there seems to be no easier way.
This is the man page (from Ubuntu): http://manpages.ubuntu.com/manpages/bionic/man1/autorandr.1.html
And this is the source code: https://github.com/phillipberndt/autorandr
Install it in Ubuntu with:
sudo apt install autorandr
Then just save your current config with:
autorandr -s myFaveConfig
and change config and save others with
autorandr -s myOtherConfig
Then just apply them whenever you want with:
autorandr [theConfigIwant]
for example:
autorandr myFaveConfig
will load the first config you saved in this example.
Nothing easier !!
Have you already installed the Nvidia video drivers? I had problems with low resolution and discovered that my system didn't have the Nvidia driver. I don't have the exact command now, but it's something like this. I suggest doing research on it:
sudo apt install nvidia-driver-[version]
