I have a computer using Ubuntu 14.04 LTS with the ASUS Nvidia gt440 graphics card and a vga monitor that is supported with the resolution of 1280 X 800.
However, in the display options I could not find 1280 X 800 and all the other options are either causing screen to flicker or just lower resolution.
Is there a way to add a custom resolution in the display settings?
You can use xrandr:
The commands to be executed in order (Using 1280 x 800 as your desired resolution):
cvt 1280 800
xrandr --newmode "1280x800_60.00" 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync
The part of the line after xrandr --newmode is similar to the ouput you should get when using the cvt command, so copy the output from the "resolution_refreshRate" ("1280x800_60.00" here) point to the +vsync point and add it to xrandr --newmode.
Then:
xrandr --addmode LVDS1 resolution_refreshRate (don't use speechmarks)
xrandr --output LVDS1 --mode resolution_refreshRate
If you want to make the changes permanent:
  • Create a bash script, xrandr.sh for example, and place your xrandr commands into it:
    #!/bin/bash
    sudo xrandr --newmode ""1280x800_60.00"" 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync
    sudo xrandr --addmode LVDS1 1280x800_60.00
    xrandr --output LVDS1 --mode 1280x800_60.00
  • Make the script executable with chmod +x xrandr.sh
  • Search for "Startup Applications" in the dash, run it, and add the script as a startup application.
The commands will now run every time you log into your account.
Note: I'm using LVDS1 as the supposed monitor name, but yours probably won't be the same. You can find your monitor name using:
xrandr | grep " connected " | awk '{ print$1 }'
TellMeWhy
  • 17,964
  • 41
  • 100
  • 142
