After some updates and a recent reboot, my screen resolution went bonkers. My problem is similar to this one and also this one, but the solutions presented there do not fix my problem. The correct setting for my monitor is 1920:1200 (i.e. 8:5 aspect ratio) at 60 Hz, but Ubuntu only offers 1600x1200 and says "Unknown display". So not only is the resolution wrong, but everything on my screen looks stretched horizontally. This is what I have done:
% cvt 1920 1200 60
# 1920x1200 59.88 Hz (CVT 2.30MA) hsync: 74.56 kHz; pclk: 193.25 MHz
Modeline "1920x1200_60.00" 193.25 1920 2056 2256 2592 1200 1203
1209 1245 -hsync +vsync
% xrandr --newmode "1920x1200_60" 193.25 1920 2056 2256 2592 1200
1203 1209 1245 -hsync +vsync
xrandr: Failed to get size of gamma for output default
% xrandr --addmode default 1920x1200_60
% xrandr --output default --mode 1920x1200_60
xrandr: Configure crtc 0 failed
% xrandr -s 1920x1200
Failed to change the screen configuration!
% xrandr
Screen 0: minimum 1600 x 1200, current 1600 x 1200, maximum 1920 x 1200
default connected primary 1600x1200+0+0 0mm x 0mm
1600x1200 77.00*
1920x1200_60 59.88
At this point, if I go to "Displays" in the GUI, my display is still called "Unknown Display", but at least "1920x1200 (16:10)" shows up as one of the resolutions. But when I select that and click "Apply", Ubuntu doesn't actually change the resolution (but it asks me if I want to keep my "new" resolution).
Btw, notice my use of "default" where most advice comments put "VGA" or "HDMI" or similar... xrand does not recognize any of those things. It really has no idea what my display is and the only way I seem to be able to refer to it as as "default".
I don't know what else to do. I have been trying to fix this since yesterday and nothing seems to work. My attempts to write an xorg.conf file just gave me a black screen (and I and to boot in "failsafe" mode to remove xorg.conf).
I have been able to make an xorg.conf file that doesn't make my computer go bonkers. In fact, though it doesn't fix my problem, it does add more resolutions to the list. So clearly it's doing "something". This is the xorg.conf file:
Section "Device"
Identifier "Configured Video Device"
Driver "vesa"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
Modeline "1920x1200" 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
Device "Configured Video Device"
SubSection "Display"
Modes "1920x1200_60"
EndSubSection
EndSection
The result of using this file is that when I boot into Ubuntu and go to "Displays", I actually see a list of options:
- 1600x1200 (4:3)
- 1280x1024 (5:4)
- 1024x768 (4:3)
- 800x600 (4:3)
So... the new options aren't any good, and it's still "Unknown Display". But this is the first time I got an xorg.conf file that didn't completely hose the system. I hope that a clever mind can turn this into a solution.
Output of lspci
% lspci|grep -i vga
0f:00.0 VGA compatible controller: NVIDIA Corporation GF106GL
[Quadro 2000] (rev a1)
So Ubuntu knows that I have an Nvidia graphics card. Right now I am using the open source X.Org Nouveau driver, but I have tried the binary drivers from NVidia too. When I go to the "Software and Updates" program and go to the "Additional Drivers" tab, Ubuntu offers me the open source driver and various binary drivers. The most recent binary driver it offers is 367.57 and that one doesn't fix the issue, nor does it get Ubuntu to call my display anything other than "Unknown Display".
