I'm getting an error in software updater when I try and do my daily updates. it says:
The upgrade needs a total of 25.3 M free space on disk `/boot`.
Please free at least an additional 25.3 M of disk space on `/boot`.
Empty your trash and remove temporary packages of former installations
using `sudo apt-get clean`.
I tried typing in sudo apt-get clean into the Terminal but I still get the message. All of the pages I read seem to be for experienced Ubuntuers. I'm running Ubuntu 12.10. I want to upgrade to 13.04 but understand I have to finish these first.
This is the output from typing in cat /etc/fstab into the Terminal:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
/dev/mapper/ubuntu-root / ext4 errors=remount-ro 0 1
# /boot was on /dev/sda1 during installation
UUID=fa55c082-112d-4b10-bcf3-e7ffec6cebbc /boot ext2 defaults 0 2
/dev/mapper/ubuntu-swap_1 none swap sw 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto,exec,utf8 0 0
matty@matty-G41M-ES2L:~$
Output of df -h:
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/ubuntu-root 915G 27G 842G 4% /
udev 984M 4.0K 984M 1% /dev
tmpfs 397M 1.1M 396M 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 992M 1.8M 990M 1% /run/shm
none 100M 52K 100M 1% /run/user
/dev/sda1 228M 222M 0 100% /boot
And dpkg -l | grep linux-image gives:
ii linux-image-3.5.0-17-generic 3.5.0-17.28 i386 Linux kernel image for version 3.5.0 on 32 bit x86 SMP
ii linux-image-3.5.0-18-generic 3.5.0-18.29 i386 Linux kernel image for version 3.5.0 on 32 bit x86 SMP
ii linux-image-3.5.0-19-generic 3.5.0-19.30 i386 Linux kernel image for version 3.5.0 on 32 bit x86 SMP
ii linux-image-3.5.0-21-generic 3.5.0-21.32 i386 Linux kernel image for version 3.5.0 on 32 bit x86 SMP
ii linux-image-3.5.0-22-generic 3.5.0-22.34 i386 Linux kernel image for version 3.5.0 on 32 bit x86 SMP
ii linux-image-3.5.0-23-generic 3.5.0-23.35 i386 Linux kernel image for version 3.5.0 on 32 bit x86 SMP
ii linux-image-3.5.0-24-generic 3.5.0-24.37 i386 Linux kernel image for version 3.5.0 on 32 bit x86 SMP
ii linux-image-3.5.0-25-generic 3.5.0-25.39 i386 Linux kernel image for version 3.5.0 on 32 bit x86 SMP
ii linux-image-3.5.0-26-generic 3.5.0-26.42 i386 Linux kernel image for version 3.5.0 on 32 bit x86 SMP
iF linux-image-3.5.0-28-generic 3.5.0-28.48 i386 Linux kernel image for version 3.5.0 on 32 bit x86 SMP
