I will give a bit of a back story to how I got this issue, The first issue I has was I have a full /boot disk and could not do anything. I moved some of the unused config files to another disk and managed to get enough space to remove some of the kernels as instructed by other posts on this site and many others.
Now, it asks me to do apt-get -f install when ever I try install, remove.. etc anything with apt-get. I looked around and it mentioned to do dpkg --configure -a So I tried that and that did not fix the issue.
Here are some outputs.
root@DownloadServer:/boot# apt-get -f install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
linux-generic
The following packages will be upgraded:
linux-generic
1 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
1 not fully installed or removed.
Need to get 0 B/1,720 B of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
dpkg: dependency problems prevent configuration of linux-generic:
linux-generic depends on linux-image-generic (= 3.2.0.43.51); however:
Version of linux-image-generic on system is 3.2.0.44.53.
linux-generic depends on linux-headers-generic (= 3.2.0.43.51); however:
Version of linux-headers-generic on system is 3.2.0.44.53.
dpkg: error processing linux-generic (--configure):
dependency problems - leaving unconfigured
No apport report written because MaxReports has already been reached
linux-generic
root@DownloadServer:/boot# dpkg --configure -a
linux-generic
Not sure if this info is useful but I'm running on 3.2.0-34-generic - (uname -r)
Please let me know if you need more info. Thanks in advance.
EDIT for more info:
root@DownloadServer:/boot# dpkg -l | grep linux-image
ii linux-image-3.2.0-33-generic 3.2.0-33.52 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-3.2.0-34-generic 3.2.0-34.53 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-3.2.0-35-generic 3.2.0-35.55 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-3.2.0-36-generic 3.2.0-36.57 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-3.2.0-37-generic 3.2.0-37.58 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-3.2.0-38-generic 3.2.0-38.61 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-3.2.0-39-generic 3.2.0-39.62 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-3.2.0-40-generic 3.2.0-40.64 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-3.2.0-41-generic 3.2.0-41.66 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-3.2.0-43-generic 3.2.0-43.68 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-3.2.0-44-generic 3.2.0-44.69 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-generic 3.2.0.44.53 Generic Linux kernel image
