I am using Ubuntu 15.10 and am trying to upgrade to a newer distribution. I get the following errors when I try to upgrade:
Not enough free disk space
The upgrade has aborted. The upgrade needs a total of 1,134 M free
space on disk '/var'. Please free at least an additional 896 M of
disk space on '/var'. Empty your trash and remove temporary packages
of former installations using 'sudo apt-get clean'.
The upgrade has aborted. The upgrade needs a total of 873 M free
space on disk '/usr'. Please free at least an additional 11.3 M of
disk space on '/usr'. Empty your trash and remove temporary packages
My df -h looks like this:
Filesystem Size Used Avail Use% Mounted on
udev 3.9G 0 3.9G 0% /dev
tmpfs 784M 9.8M 774M 2% /run
/dev/sdb6 19G 505M 17G 3% /
/dev/sdb9 5.4G 4.3G 823M 85% /usr
tmpfs 3.9G 26M 3.9G 1% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
/dev/sdb10 2.7G 86M 2.5G 4% /usr/local
/dev/sdb13 1.9G 2.9M 1.7G 1% /srv
/dev/sdb14 1.9G 2.9M 1.7G 1% /opt
/dev/sdb7 227M 60M 151M 29% /boot
/dev/sdb1 496M 38M 459M 8% /boot/efi
/dev/sdb11 1.9G 27M 1.7G 2% /tmp
/dev/sdb12 1.9G 1.5G 275M 85% /var
/dev/sdb15 144G 25G 112G 19% /home
cgmfs 100K 0 100K 0% /run/cgmanager/fs
tmpfs 784M 48K 784M 1% /run/user/1000
Although most of the solutions on here seems to point to an issue with /boot being full, I don't think my issue is the same. When I run ls /boot, I get:
abi-4.2.0-36-generic memtest86+.bin
config-4.2.0-36-generic memtest86+.elf
efi memtest86+_multiboot.bin
grub System.map-4.2.0-36-generic
initrd.img-4.2.0-36-generic vmlinuz-4.2.0-36-generic
lost+found vmlinuz-4.2.0-36-generic.efi.signed
So I don't think I can delete anything else on here.
I have tried various other solutions from using sudo apt-get clean to sudo apt-get autoremove, but nothing seems to work. How should I approach this issue?
