Every time I install or uninstall using the Ubuntu Software Center I get this message:
Package Operation Failed
The installation or removal of the software package failed.
I get this for every download right as the download finishes, yet when I click OK it seems that what I downloaded is still there
Example:
installArchives() failed: Selecting previously unselected package libdc5:i386.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 191527 files and directories currently installed.)
Preparing to unpack .../libdc5_0.3.24~svn3121-2_i386.deb ...
Unpacking libdc5:i386 (0.3.24~svn3121-2) ...
Selecting previously unselected package libqt4-qt3support:i386.
Preparing to unpack .../libqt4-qt3support_4%3a4.8.5+git192-g085f851+dfsg-
2ubuntu4_i386.deb ...
Unpacking libqt4-^^^^qt3support:i386 (4:4.8.5+git192-g085f851+dfsg-2ubuntu4) ...
Selecting previously unselected package valknut.
Preparing to unpack .../valknut_0.4.9-2ubuntu1_i386.deb ...
Unpacking valknut (0.4.9-2ubuntu1) ...
Selecting previously unselected package valknut-translations.
Preparing to unpack .../valknut-translations_0.4.9-2ubuntu1_all.deb ...
Unpacking valknut-translations (0.4.9-2ubuntu1) ...
Processing triggers for gnome-menus (3.10.1-0ubuntu2) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu1) ...
Processing triggers for bamfdaemon (0.5.1+14.04.20140409-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for mime-support (3.54ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.13-1) ...
Processing triggers for menu (2.1.46ubuntu1) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Setting up mandos-client (1.6.0-1) ...
Note: Due to entropy requirements, key generation could take
anything from a few minutes to SEVERAL HOURS.  Please be
patient and/or supply the system with more entropy if needed.
Started: Thu Dec 18 19:18:41 PST 2014
gpg: WARNING: some OpenPGP programs can't handle a DSA key with this digest size
gpg: fatal: can't open `/tmp/mandos-keygen-keyrings.tCwFYmaNzz/trustdb.gpg': No such >file or directory
secmem usage: 3424/4896 bytes in 8/14 blocks of pool 5760/32768
dpkg: error processing package mandos-client (--configure):
 subprocess installed post-installation script returned error exit status 2
Setting up libdc5:i386 (0.3.24~svn3121-2) ...
Setting up libqt4-qt3support:i386 (4:4.8.5+git192-g085f851+dfsg-2ubuntu4) ...
Setting up valknut (0.4.9-2ubuntu1) ...
Setting up valknut-translations (0.4.9-2ubuntu1) ...
Processing triggers for libc-bin (2.19-0ubuntu6.4) ...
 mandos-client
Error in function:
Started: Thu Dec 18 19:20:20 PST 2014
gpg: fatal: can't open `/tmp/mandos-keygen-keyrings.O6N6nUJILO/trustdb.gpg': No such >file or directory
secmem usage: 3424/4896 bytes in 8/14 blocks of pool 5728/32768
I ran sudo dpkg --configure -a :
Started: Thu Dec 18 19:48:32 PST 2014
gpg: fatal: can't open `/tmp/mandos-keygen-keyrings.e8PUgDtyvI/trustdb.gpg': No such file or directory
 mandos-client
Results of sudo apt-get upgrade :
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Started: Thu Dec 18 19:14:12 PST 2014
gpg: fatal: can't open `/tmp/mandos-keygen-keyrings.hfuSU3sSIu/trustdb.gpg': No such >file or directory
 mandos-client
Now, it doesn't seem like anything is going wrong. I tried a few other commands such as sudo apt-get -f install, sudo apt-get clean and sudo apt-get auto clean
I also followed the instructions here, but it didn't work.
This didn't start happening until purging using the instructions for not enough free space when upgrading.
karel
  • 122,292
  • 133
  • 301
  • 332
Shut Up
  • 23
Did you give a try with purging mandos-client?
$ sudo apt-get autoremove --purge  mandos-client
This should remove this package in a clean way, so that you can install later.
