I have Broadcom wifi adapter and after upgrading to kernel linux 4.4 on ubuntu 14.04 LTS it stoped working.
My Broadcom :
0c:00.0 Network controller [0280]: Broadcom Corporation BCM4322 802.11a/b/g/n Wireless LAN Controller [14e4:432b] (rev 01)
Now I'm using my computer with advanced options from boot menu set to the old kernel 3.16.0-77-generic.
Initially I used this question to install the Broadcom Wireless.
What is the solution to this issue? Should I aspect more issues generated by the kernel update?
If there is no solution yet to this, how can I roll back the 4.4 kernel update to the old one 3.16?
Meanwhile I used this to free up space in inodes and atemted to update to 4.4.0-45 kernel. Same result. The wireles does not work. I must delete it and return to the old 3.16 kernel.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
I found a temporary fix to this issue. From the grub menu I chosed advanced and I selected the old 3.16 kernel. After loging in into this kernel I followed the method exposed here Not enough free disk space when upgrading to delete de new 4.4.0-xx-generic kernel/kernels.
EDIT 26.12.2016
I made an update from 3.16 kernel to 4.4.0-58 on another identical laptop and this time the above problem didn't apear. It seems that the update contains the solution.
Thanks to Ubuntu developers.
Since kernel v4.4 is from Ubuntu Xenial, as a workaround you can use the bcmwl-kernel-source package from Xenial too (source):
  1. Go to https://launchpad.net/ubuntu/xenial/+package/bcmwl-kernel-source and select the package with the highest version with “(Release)” behind it for your architecture (currently 6.30.223.248+bdcom-0ubuntu8).
  2. On the page for that release build in the section “Downloadable files” select and download the only Deb package built (e. g. currently bcmwl-kernel-source_6.30.223.248+bdcom-0ubuntu8_i386.deb for i386).
  3. Install that package with Software Center or GDebi or directly with dpkg:
    sudo dpkg -i bcmwl-kernel-source_*_$(dpkg --print-architecture).deb
    If there are missing dependencies follow up with:
    sudo apt-get install -f
This should allow your system to build the kernel module with the wireless adapter driver for kernel v4.4 successfully. As a side effect it you may not have a working driver in earlier kernel versions (e. g. 3.13 or 3.16).
David Foerster
  • 36,890
  • 56
  • 97
  • 151
