Yesterday I was having problems with Lubuntu 14.04 updates machine I had to follow this check-marked answer Not enough free disk space when upgrading
The answer worked well but Today when I turned on my computer I could not connect to any network (either wifi or ethernet) they are just not showing up. Furthermore After running: sudo lshw -C network -numeric I get
*-network UNCLAIMED
       description: Ethernet controller
       product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller [10EC:8136]
       vendor: Realtek Semiconductor Co., Ltd. [10EC]
       physical id: 0
       bus info: pci@0000:01:00.0
       version: 07
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list
       configuration: latency=0
       resources: ioport:3000(size=256) memory:b0600000-b0600fff memory:b0400000-b0403fff
  *-network UNCLAIMED
       description: Network controller
       product: QCA9565 / AR9565 Wireless Network Adapter [168C:36]
       vendor: Qualcomm Atheros [168C]
       physical id: 0
       bus info: pci@0000:02:00.0
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       resources: memory:b0500000-b057ffff memory:9fb00000-9fb0ffff
As you can see both networks appear unclaimed, which from what I've read makes me suspect that is a drivers problem. Is there anyway to get this working back again without having to do a clean re-install. I just do not want set up all my dev environment from scratch.
EDIT
After dpkg -l | grep linux-image
ii  linux-image-3.13.0-40-generic 3.13.0-40.69 i386 Linux kernel image for version 3.13.0 on 32 bit x86 SMP
ii  linux-image-3.13.0-43-generic 3.13.0-43.72 i386 Linux kernel image for version 3.13.0 on 32 bit x86 SMP
ii  linux-image-3.13.0-45-generic 3.13.0-45.74 i386 Linux kernel image for version 3.13.0 on 32 bit x86 SMP
ii  linux-image-extra-3.13.0-40-generic 3.13.0-40.69 i386  Linux kernel extra modules for version 3.13.0 on 32 bit x86 SMP
ii  linux-image-extra-3.13.0-43-generic 3.13.0-43.72 i386  Linux kernel extra modules for version 3.13.0 on 32 bit x86 SMP
ii  linux-image-generic 3.13.0.43.50 i386 Generic Linux kernel image
uname -r
3.13.0-45-generic
La Murga
  • 265
I suggest you reboot into an earlier linux-image by selecting it at the GRUB menu as I linked above. Afterwards, reinstall the faulty version:
sudo apt-get install --reinstall linux-image-3.13.0-45-generic
When finished, reboot and test.
chili555
  • 61,330
