I have a virtual box setup for Ubuntu 16.04. On metal exists Mac OS.
The drive on which virtual box image exists has 23+ GB available.
Following is the outputs I took from the Ubuntu terminal.
For command du -f:
Filesystem Size Used Avail Use% Mounted on
udev 2.0G 0 2.0G 0% /dev
tmpfs 396M 5.9M 390M 2% /run
/dev/sda1 17G 15G 1.6G 90% /
tmpfs 2.0G 0 2.0G 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
tmpfs 396M 0 396M 0% /run/user/124
tmpfs 396M 0 396M 0% /run/user/1000
Another output for the command lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 60G 0 disk
├─sda1 8:1 0 17G 0 part /
├─sda2 8:2 0 1K 0 part
└─sda5 8:5 0 3G 0 part [SWAP]
sr0 11:0 1 1024M 0 rom
Issue although it shows I should have 60GB memory, virtual box shouts it is full even if 20 GB is filled.
Any possible fixes?
