There are several guides that speak of the same way. Guides like this source, this source or the bug report mention some procedures to get this Wireless card working on several types of laptops.
Some cases mention downgrading to 12.04 and then installing a specific 3.6 kernel version for it, others mention upgrading to 13.04 and installing the 3.9 kernel version. And even another case where it mentions the user to download the drivers from the official site and do a step by step guide on how to install it.
I will mention several ways of doing it, all of which involve downloading the driver, compiling it and making sure it works. It has been noted that in the 3.9 kernel version, the wireless card is working correctly, so in 13.04 with backports or 13.10 this issue should be resolved.
So here are several ways you can get your Ralink RT3290 wireless card working in 12.04 and above (Not all methods will work, so try to look for the one that works best for your computer):
Since your vendor id is 1814:3290 it means you have a Ralink RT3290 wireless card. For that case we (After connecting the wired cable):
Connect a wired cable connection to the computer to have Internet connection for the moment while you do the steps below.
Open a terminal and execute the following line to install everything needed to compile your very own wireless drivers:
sudo apt-get update && sudo apt-get install build-essential linux-headers-generic
Now, depending on how you wish to proceed, follow one of the guides below:
NOT OFFICIAL DRIVERS FOR Kernel 4.X
If the above does not work for you on Kernels 4.X, the solution I was able to test following this source was
PLease Download the Updated Driver (Big Thanks to Jim Colaco) From Here or Here. This was tested on Ubuntu 16.04 and 16.10.
sudo tar -xvf rt3290sta-2.6.0.0.dkms.tar -C /usr/src
sudo dkms install -m rt3290sta -v 2.6.0.0 --force
sudo reboot
Now on some cases, you will need to enable the interface for the wireless driver (Because it will not bring the interface up automatically) and then restart the network service. Something like this:
sudo ifconfig WIRELESSCARD up
sudo service network-manager restart
So an example would be:
sudo ifconfig eno1 up
I recommend putting this 2 lines inside /etc/rc.local above the "exit 0" line so it brings the interface up automatically.
OFFICIAL SITE GUIDE
Go to Mediatek and download the Ralink RT3290 Driver for Linux MediaTek did a fine job on moving the link to download and not having a redirect for it. Here is the new Link for all Downloadable Firmware but guess what, they removed RT3290 from it. Go Mediatek ;)
Thanks to others that also had the problem and shared their sources, here is a list of all available Download links for you to use while Mediatek decides to help Linux and open up:
Rename the file to 2012_0508_RT3290_Linux_STA_v2.6.0.0.tar.bz2 because Mediatek did a great job on making sure the file works correctly.
Extract the file and it should create a folder named DPO_RT3290_LinuxSTA_V2600_20120508
Go to DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/ and edit the file config.mk
On line 31 you should find the variable HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=n. Change it to
HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=y
and save the file.
Go to your main extracted folder (It should be the DPO_RT3290_LinuxSTA_V2600_20120508 folder) and type:
make
sudo make install
If everything compiled correctly do the following:
modprobe rt3290sta
If step 7 runs without any problems, we add the module to the list of modules to loaded on every boot:
sudo -H gedit /etc/modules
and add a line at the end of the file that says rt3290sta. Save and exit.
DROPBOX GUIDE
(Not recommended, as you're downloading an untrusted tarball off of a Dropbox account.
Download the source driver:
wget http://dl.dropbox.com/u/11876059/DPO_RT3290_LinuxSTA_V2600_20120508.tar.gz
and we then decompress the file
tar -xvf DPO_RT3290_LinuxSTA_V2600_20120508.tar.gz
Go inside the newly created folder:
cd ~/DPO_RT3290_LinuxSTA_V2600_20120508
and we start the compiling process
make
sudo make install
We then test to see if the driver is correctly compiled and installed
sudo modprobe rt3290sta
If step 3 runs without any problems we then add the module to the list of modules to loaded upon every boot:
and add a line at the bottom that says rt3290sta. Save and exit.
EXTRA GUIDE
Some users mention additional steps. This might or not apply to you. If you feel the system is not working, maybe one of the points below can help you along the way:
When opening the config.mk file, do not only change the HAS_NATIVE_WPA_SUPPLICANT to a value of y, but also do it with HAS_WPA_SUPPLICANT in case it has n. In my case it had y but it should be checked to make sure both WPA_SUPPLICANT are set to `y.
Blacklisting conflicting wireless drivers. Do the following:
sudo -H gedit /etc/modprobe.d/blacklist.conf
Add the following lines (Make sure they are not there in the first place):
#Wireless drivers conflicting with rt3562sta
blacklist rt2800pci
blacklist rt2x00pci
Update initramfs: sudo update-initramfs -u
If you have trouble compiling the driver on Ubuntu 13.04 or Ubuntu 13.10 (and perhaps later versions as well), then this may be because of a change to the Linux kernel creating an incompatibility with the driver code. This can possibly be fixed by opening
gedit os/linux/pci_main_dev.c
and adding the following after the "#include " near the top
#if LINUX_VERSION_CODE >= KERNEL_VERSION(3,8,0)
#define __devexit
#define __devinit
#define __devinitdata
#endif
then change the portion of the file which says
#if LINUX_VERSION_CODE >= 0x20412
remove: __devexit_p(rt2860_remove_one),
#else
remove: __devexit(rt2860_remove_one),
#endif
to
remove: rt2860_remove_one,
#else
#else
#endif
#endif
This will hopefully solve the compiler error. Return to the DPO_RT3290_LinuxSTA_V2600_20120508 directory and follow the instructions as above.
