Let's start by saying I'm still a total noob to Linux, my problem is that I'm trying to install a driver for my Wireless Card and got an error while trying to install the driver by using the command modprobe rt3290sta, the error is this:
What I did is I untared the driver I downloaded from this guide How do I get a Ralink RT3290 wireless card working?
http://www.mediafire.com/download/l3zoch2y1hbcali/RT3290.tar.gz
And after extracting I found out that the structure of the tar is not the same as in the guide so I extracted the src.tar.gz in the folder too and I stops at modprobe rt3290sta:
modprobe: ERROR: could not insert 'rt3290sta': Operation not permitted
The results are for other commands are as below:
lspci -vnn | grep Network
02:00.0 Network controller [0280]: Ralink corp. RT3290 Wireless 802.11n 1T/1R PCIe [1814:3290]
iwconfig
wlo1      IEEE 802.11bgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
enx001e101f0000  no wireless extensions.
eno1      no wireless extensions.
lo        no wireless extensions.
I add that the WiFi appears correctly on the menu panel.
Pardon-me, English is not my native language and neither does code.
Pang
  • 373
You need to use "sudo" with the modprobe command, like this:
sudo modprobe rt3290sta
...then enter your admin password (your password)
Cheers, Al
heynnema
  • 73,649
