I just installed Ubuntu 12.04 on 3 HP Probook 4540s's, and none of them seems to be able to connect to wireless networks.
I have 1 Probook 4540s with Windows 7 installed and I can access wlan from it. I tried installing the necessary drivers from HP's website, but it still doesn't seem to be working.
I've seen other people with different Probooks having similar problems, but their computers seem to be able to detect and even attempt to connect wlans, while mine doesn't even acknowledge that it has wireless.
output from sudo make:
make -C tools
make[1]: Entering directory `/home/olimp3/Downloads/Driver/Files/tools'
gcc -g bin2h.c -o bin2h
make[1]: Leaving directory `/home/olimp3/Downloads/Driver/Files/tools'
/home/olimp3/Downloads/Driver/Files/tools/bin2h
cp -f os/linux/Makefile.6 /home/olimp3/Downloads/Driver/Files/os/linux/Makefile
make -C /lib/modules/3.2.0-34-generic/build SUBDIRS=/home/olimp3/Downloads/Driver/Files/os/linux modules
make[1]: Entering directory `/usr/src/linux-headers-3.2.0-34-generic'
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/crypt_md5.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/crypt_sha2.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/crypt_hmac.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/crypt_aes.o
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/crypt_aes.c: In function ‘AES_Key_Wrap’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/crypt_aes.c:1466:6: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘long unsigned int’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/crypt_aes.c: In function ‘AES_Key_Unwrap’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/crypt_aes.c:1561:6: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘long unsigned int’ [-Wformat]
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/crypt_arc4.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/mlme.o
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/mlme.c: In function ‘MlmeResetRalinkCounters’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/mlme.c:528:3: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_wep.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/action.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_data.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/rtmp_init.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/rtmp_init_inf.o
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/rtmp_init_inf.c: In function ‘rt28xx_init’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/rtmp_init_inf.c:162:3: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/rtmp_init_inf.c:178:10: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_tkip.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_aes.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_sync.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/eeprom.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_sanity.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_info.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_cfg.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_wpa.o
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_wpa.c: In function ‘PeerPairMsg3Action’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_wpa.c:1032:13: warning: unused variable ‘Cancelled’ [-Wunused-variable]
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_radar.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/spectrum.o
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/spectrum.c: In function ‘PeerMeasureReportAction’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/spectrum.c:1972:3: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘long unsigned int’ [-Wformat]
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/rtmp_timer.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/rt_channel.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_profile.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_asic.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_cmd.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/ps.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/uapsd.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../rate_ctrl/ra_ctrl.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../rate_ctrl/alg_legacy.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../rate_ctrl/alg_ags.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rtmp_chip.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../sta/assoc.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../sta/auth.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../sta/auth_rsp.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../sta/sync.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../sta/sanity.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../sta/rtmp_data.o
/home/olimp3/Downloads/Driver/Files/os/linux/../../sta/rtmp_data.c: In function ‘STAHandleRxDataFrame’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../sta/rtmp_data.c:283:17: warning: unused variable ‘pFmeCtrl’ [-Wunused-variable]
/home/olimp3/Downloads/Driver/Files/os/linux/../../sta/rtmp_data.c:282:8: warning: unused variable ‘OldPwrMgmt’ [-Wunused-variable]
/home/olimp3/Downloads/Driver/Files/os/linux/../../sta/rtmp_data.c: In function ‘STAHandleRxMgmtFrame’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../sta/rtmp_data.c:766:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../sta/connect.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../sta/wpa.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../sta/sta_cfg.o
/home/olimp3/Downloads/Driver/Files/os/linux/../../sta/sta_cfg.c: In function ‘RTMPQueryInformation’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../sta/sta_cfg.c:3956:4: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘long unsigned int’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../sta/sta_cfg.c: In function ‘RtmpIoctl_rt_private_get_statistics’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../sta/sta_cfg.c:7220:1: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 3 has type ‘EEPROM_NIC_CONFIG3_STRUC’ [-Wformat]
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/rt_os_util.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/ba_action.o
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/ba_action.c: In function ‘convert_reordering_packet_to_preAMSDU_or_802_3_packet’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/ba_action.c:1550:2: warning: assignment makes integer from pointer without a cast [enabled by default]
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/rt_led.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_mac_pci.o
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_mac_pci.c: In function ‘RT28xxPciMlmeRadioOn’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_mac_pci.c:2245:13: warning: unused variable ‘Cancelled’ [-Wunused-variable]
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_data_pci.o
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_data_pci.c: In function ‘RTMPFreeTXDUponTxDmaDone’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_data_pci.c:543:8: warning: unused variable ‘TXWISize’ [-Wunused-variable]
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_data_pci.c: In function ‘RTMPHandleMgmtRingDmaDoneInterrupt’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/cmm_data_pci.c:738:8: warning: unused variable ‘TXWISize’ [-Wunused-variable]
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/rtmp_mcu.o
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/rtmp_mcu.c: In function ‘RtmpAsicSendCommandToMcu’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/rtmp_mcu.c:464:8: warning: unused variable ‘offset’ [-Wunused-variable]
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/rtmp_mcu.c:463:8: warning: unused variable ‘Configuration’ [-Wunused-variable]
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/ee_prom.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/ee_efuse.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/rt_rf.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt30xx.o
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.o
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c: In function ‘RT3290_AsicTxAlcGetAutoAgcOffset’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:1564:25: warning: assignment discards ‘const’ qualifier from pointer target type [enabled by default]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c: In function ‘MlmeAntSelection’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2489:4: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2489:4: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2489:4: warning: format ‘%d’ expects argument of type ‘int’, but argument 4 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2507:5: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2522:5: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2522:5: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2523:5: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2523:5: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2526:5: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2526:5: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2527:5: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2527:5: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2528:5: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2528:5: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2545:6: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2545:6: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2545:6: warning: format ‘%d’ expects argument of type ‘int’, but argument 4 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2559:9: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2565:9: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2574:8: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2581:8: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2583:7: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2583:7: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2595:6: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2595:6: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2596:6: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2596:6: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2597:6: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:2597:6: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c: In function ‘BtCoexSetting’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:3244:4: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘ULONG’ [-Wformat]
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c: In function ‘Profile_TwoAnt’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../chips/rt3290.c:4097:2: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 2 has type ‘CMB_CTRL_STRUC’ [-Wformat]
CC [M] /home/olimp3/Downloads/Driver/Files/os/linux/../../common/frq_cal.o
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/frq_cal.c: In function ‘FrequencyCalibration’:
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/frq_cal.c:198:18: warning: comparison of distinct pointer types lacks a cast [enabled by default]
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/frq_cal.c:211:18: warning: comparison of distinct pointer types lacks a cast [enabled by default]
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/frq_cal.c:227:18: warning: comparison of distinct pointer types lacks a cast [enabled by default]
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/frq_cal.c:252:18: warning: comparison of distinct pointer types lacks a cast [enabled by default]
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/frq_cal.c:265:18: warning: comparison of distinct pointer types lacks a cast [enabled by default]
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/frq_cal.c:281:18: warning: comparison of distinct pointer types lacks a cast [enabled by default]
/home/olimp3/Downloads/Driver/Files/os/linux/../../common/frq_cal.c:132:10: warning: unused variable ‘bUpdateRFR’ [-Wunused-variable]
LD [M] /home/olimp3/Downloads/Driver/Files/os/linux/rt3290sta.o
Building modules, stage 2.
MODPOST 1 modules
WARNING: modpost: missing MODULE_LICENSE() in /home/olimp3/Downloads/Driver/Files/os/linux/rt3290sta.o
see include/linux/module.h for more information
LD [M] /home/olimp3/Downloads/Driver/Files/os/linux/rt3290sta.ko
make[1]: Leaving directory `/usr/src/linux-headers-3.2.0-34-generic'
cp -f /home/olimp3/Downloads/Driver/Files/os/linux/rt3290sta.ko /tftpboot
output from lspci -nnk | grep -EA3 Ralink:
04:00.0 Network controller [0280]: Ralink corp. Device [1814:3290]
Subsystem: Hewlett-Packard Company Device [103c:18ec]
04:00.1 Bluetooth [0d11]: Ralink corp. Device [1814:3298]
05:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller [10ec:8168] (rev 07)
Subsystem: Hewlett-Packard Company Device [103c:17f6]
