I'm new to Ubuntu. How can i install wifi driver Ralink RT3290 802.11bgn? And please if you can help me step by step :D Thank you very much!
Since Ralink does not patch the driver and the current version does not work, I provided a patched file that you can download and install following this steps
download the patched file from my private Google Drive directory.
open a terminal (Ctrl+Alt+t) and
cdinto the folder where the file is downloaded, e.g.cd ~/Downloads.type
sudo tar -xvf rt3290sta-2.6.0.0.dkms.tar -C /usr/srcto untar the content in a system directory
you should now get a password prompt where you type the
sudopassword and press Enter.once the files are all extracted type
sudo dkms install -m rt3290sta -v 2.6.0.0 --forceto install the driver with
dkmsenter
sudopassword again and ensure that install is completed successfully (it will take some time).reboot.
Enjoy Wi-Fi with your
RT3290:D
The patch will work up to kernel version v4.14, it breaks on v4.15 onwards due to the change in the kernel timer implementations.
- 3
- 3
- 111
NOTE: The links referred to here may no longer operate. They are left in here for historical purposes only.
Download the source code of the driver:
wget http://dl.dropbox.com/u/11876059/DPO_RT3290_LinuxSTA_V2600_20120508.tar.gzthen extract the file from tar file
tar -xvf DPO_RT3290_LinuxSTA_V2600_20120508.tar.gzafter that enter to this dir
cd ~/DPO_RT3290_LinuxSTA_V2600_20120508 make # compile the make file sudo make install # install the make fileAfter that activate the wireless driver
sudo modprobe rt3290sta
- 78,878
- 300
whoever runs that wifi chip after a decade,
- in Ubuntu 24.04 / noble and up you'll find the rt3290.bin firmware blob in the linux-firmware package
- in Debian bookworm-backports/trixie (12/13) rt3290.bin went into firmware-mediatek and needs the "non-free-firmware" component in your apt source (the line where at least "main" is found). In bookworm and lower it's in firmware-misc-nonfree
no need to compile, the kernel will pick it up during boot
- 549
