I use Ubuntu16.04 and my laptop model is Asus-n552vw. My wi-fi network doesn't work properly. I thought maybe the problem solved if I update my wi-fi driver. I searched for that but couldn't find how should I do it?
EDIT: My problem is very strange and stupid! If I connect to my wi-fi network at home that has 512kbps speed, I should disconnect and reconnect for every access to internet! I mean I must disconnect/reconnect to open a new site, then I must do it again for another site, or refreshing the other apps data.
But, If I use a VPN like windscribe and connecting to it, my network works well untill I am connected to it!!!
Also when I use other network connections with 2mbps or upper speeds, it seems my network works well again!
Ubuntu 16.04 is very stable so i don't think the driver is you problem. maybe the problem is DNS(you can change it in /etc/resolve.conf) or ISP(if other devices have same problem) or hardware
by the way if you sure the problem is your driver, the drivers is in the Linux (i mean the kernel) you must upgrade your Linux and because you use Ubuntu 16.04 i don't think you can upgrade your Linux in a safely way
you can upgrade your Ubuntu to 17.10 or 18.04(it is not stable yet)
