I have upgraded from Ubuntu 13.04 to Ubuntu 13.10 and now my WiFi doesn't work. It takes a lot of time to connect but when connected, connection is quickly lost again. In Ubuntu 13.04 worked fine.
Here are some outputs:
lspci | grep Wireless
01:00.0 Network controller: Ralink corp. RT3290 Wireless 802.11n 1T/1R PCIe
sudo rfkill list
0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
lsmod | grep rt2800
rt2800pci              18966  0
rt2800lib              95449  1 rt2800pci
rt2x00pci              13287  1 rt2800pci
rt2x00mmio             13661  1 rt2800pci
rt2x00lib              56053  4 rt2x00pci,rt2800lib,rt2800pci,rt2x00mmio
mac80211              634661  3 rt2x00lib,rt2x00pci,rt2800lib
eeprom_93cx6           13344  1 rt2800pci
crc_ccitt              12707  1 rt2800lib
dmesg | grep rt2800
[   19.959959] rt2800pci 0000:01:00.0: irq 46 for MSI/MSI-X
modinfo rt2800pci | grep 3290
alias:          pci:v00001814d00003290sv*sd*bc*sc*i*
Solution for me:
It appears a Ubuntu bug, I have found a solution here:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1049466
Post 117 and +
Thanks
It should be working out of the box with the driver rt2800pci. On my system,
which shows the correct Vendr and Product id, see this Wikidevi page. You should first check that you get the same output, then please proceed with these commands:
sudo apt-get install linux-firmware-nonfree
sudo rmmod rt2800pci
sudo modprobe rt2800pci
This should take care of it.
Edit: please post the output of
sudo rfkill list
lsmod | grep rt2800
dmesg | grep rt2800
Edit: we may try to use the backport driver. You should issue these commands:
sudo apt-get install build-essential linux-headers-generic
wget https://www.kernel.org/pub/linux/kernel/projects/backports/2013/10/18/backports-20131018.tar.gz
tar xvfz backports-20131018.tar.gz
cd backports-20131018
make defconfig-wifi
make
sudo make install
