EDIT: This appears to have turned in a sort of canonical set of commands to start diagnosing audio issues.
I am using Ubuntu 20.04 for over a month now. After a reboot, I have no more sound and WiFi. Note that this is different from many other posts, which seem to have had no sound at all, after an upgrade. In this case, sound stopped working only after a reboot.
As for the sound, I seem to not have the appropriate kernel modules for sound, so I guess the most likely solution would come from making the modules available (it seems I have two sound cards). I will try to include below (1) as much info as possible related to the copious posts with similar problems.
I am listing below (2) the posts that I consider most useful at the current point of the fixing work-in-progress.
And I am listing below (3) other posts that I checked when the grass was higher.
(1) Info about my broken system, along with a comparison with what I see in a working system that I managed to put together.
- No
/proc/asounddirectory.
Versus
$ cat /proc/asound/cards
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0x604b108000 irq 159
1 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xa4000000 irq 17
$ lsmod | grep sndoutputs nothing.
Versus (also compare with this)
$ lsmod | grep snd_hda_intel
snd_hda_intel 53248 10
snd_intel_dspcfg 24576 3 snd_hda_intel,snd_sof_pci,snd_sof_intel_hda_common
snd_hda_codec 131072 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek,snd_soc_hdac_hda
snd_hda_core 90112 9 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda
snd_pcm 106496 9 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_sof,snd_sof_intel_hda_common,snd_soc_core,snd_hda_core,snd_pcm_dmaengine
snd 90112 33 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,thinkpad_acpi,snd_soc_core,snd_pcm,snd_rawmidi
- Kernel modules
$ dpkg -L linux-modules-$(uname -r) | grep snd
/lib/modules/5.4.0-40-generic/kernel/sound/core/seq/snd-seq-dummy.ko
/lib/modules/5.4.0-40-generic/kernel/sound/core/seq/snd-seq-midi-emul.ko
/lib/modules/5.4.0-40-generic/kernel/sound/core/seq/snd-seq-midi-event.ko
/lib/modules/5.4.0-40-generic/kernel/sound/core/seq/snd-seq-midi.ko
/lib/modules/5.4.0-40-generic/kernel/sound/core/seq/snd-seq-virmidi.ko
/lib/modules/5.4.0-40-generic/kernel/sound/core/seq/snd-seq.ko
/lib/modules/5.4.0-40-generic/kernel/sound/core/snd-compress.ko
/lib/modules/5.4.0-40-generic/kernel/sound/core/snd-hrtimer.ko
/lib/modules/5.4.0-40-generic/kernel/sound/core/snd-hwdep.ko
/lib/modules/5.4.0-40-generic/kernel/sound/core/snd-pcm-dmaengine.ko
/lib/modules/5.4.0-40-generic/kernel/sound/core/snd-pcm.ko
/lib/modules/5.4.0-40-generic/kernel/sound/core/snd-rawmidi.ko
/lib/modules/5.4.0-40-generic/kernel/sound/core/snd-seq-device.ko
/lib/modules/5.4.0-40-generic/kernel/sound/core/snd-timer.ko
/lib/modules/5.4.0-40-generic/kernel/sound/core/snd.ko
/lib/modules/5.4.0-40-generic/kernel/sound/drivers/pcsp/snd-pcsp.ko
/lib/modules/5.4.0-40-generic/kernel/sound/pci/snd-ens1370.ko
Versus exactly the same
How can I check if any of this is what I need?
How can I check if any of this corresponds to those from Intel listed in item #2 above?
How can I load these modules?
inxi
$ inxi -SA
System: Host: Hydrus1 Kernel: 5.4.0-40-generic x86_64 bits: 64 Desktop: Gnome 3.36.1 Distro: Ubuntu 20.04 LTS (Focal Fossa)
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio driver: N/A
Device-2: NVIDIA GF104 High Definition Audio driver: N/A
$ inxi -SA
System: Host: ViaLactea Kernel: 5.4.0-40-generic x86_64 bits: 64 Console: tty 0 Distro: Ubuntu 20.04 LTS (Focal Fossa)
Audio: Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.4.0-40-generic
lspci$ lspci -nnk | grep -A 1 Audio 00:1b.0 Audio device [0403]: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller [8086:1c20] (rev 04) DeviceName: Onboard Audio Subsystem: Dell 6 Series/C200 Series Chipset Family High Definition Audio Controller [1028:04a4] 00:1c.0 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 [8086:1c10] (rev b4) -- 01:00.1 Audio device [0403]: NVIDIA Corporation GF104 High Definition Audio Controller [10de:0beb] (rev a1) Subsystem: Dell GF104 High Definition Audio Controller [1028:04a4] 03:00.0 Network controller [0280]: Intel Corporation Centrino Ultimate-N 6300 [8086:422b] (rev 35)
Versus
$ lspci -nnk | grep -n -A 4 Audio
49:00:1f.3 Audio device [0403]: Intel Corporation Cannon Lake PCH cAVS [8086:a348] (rev 10)
50- Subsystem: Lenovo Cannon Lake PCH cAVS [17aa:225f]
51- Kernel driver in use: snd_hda_intel
52- Kernel modules: snd_hda_intel, snd_sof_pci
53-00:1f.4 SMBus [0c05]: Intel Corporation Cannon Lake PCH SMBus Controller [8086:a323] (rev 10)
67:01:00.1 Audio device [0403]: NVIDIA Corporation GP107GL High Definition Audio Controller [10de:0fb9] (rev a1)
68- Kernel driver in use: snd_hda_intel
69- Kernel modules: snd_hda_intel
70-70:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS525A PCI Express Card Reader [10ec:525a] (rev 01)
71- Subsystem: Lenovo RTS525A PCI Express Card Reader [17aa:225f]
System (Versus exactly the same kernel)
$ uname -a Linux Hydrus1 5.4.0-40-generic #44-Ubuntu SMP Tue Jun 23 00:01:04 UTC 2020 x86_64 x86_64 x86_64 GNU/LinuxTest sound
$ aplay -l aplay: device_list:274: no soundcards found...
Versus
$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC285 Analog [ALC285 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
lshw
$ lshw -C multimedia
WARNING: you should run this program as super-user.
*-multimedia UNCLAIMED
description: Audio device
product: GF104 High Definition Audio Controller
vendor: NVIDIA Corporation
physical id: 0.1
bus info: pci@0000:01:00.1
version: a1
width: 32 bits
clock: 33MHz
capabilities: bus_master cap_list
configuration: latency=0
resources: memory:e0080000-e0083fff
product: 6 Series/C200 Series Chipset Family High Definition Audio Controller
vendor: Intel Corporation
physical id: 1b
bus info: pci@0000:00:1b.0
version: 04
width: 64 bits
clock: 33MHz
resources: memory:e1e50000-e1e53fff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
Here it is quoted (note the driver)
$ sudo lshw -C multimedia
*-multimedia
product: GP104 High Definition Audio Controller
physical id: 0.1
version: a1
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:17 memory:f7080000-f7083fff
alsapackages$ dpkg -l | grep alsa ii alsa-base 1.0.25+dfsg-0ubuntu5 all ALSA driver configuration files ii alsa-tools-gui 1.1.7-1ubuntu1 amd64 GUI based ALSA utilities for specific hardware ii alsa-topology-conf 1.2.2-1 all ALSA topology configuration files ii alsa-ucm-conf 1.2.2-1ubuntu0.1 all ALSA Use Case Manager configuration files ii alsa-utils 1.2.2-1ubuntu1 amd64 Utilities for configuring and using ALSA ii gstreamer1.0-alsa:amd64 1.16.2-4 amd64 GStreamer plugin for ALSA ii libsox-fmt-alsa:amd64 14.4.2+git20190427-2 amd64 SoX alsa format I/O libraryNo sound either if I plug earphones.
I have no
timidity-daemonto remove.Attempt reload
$ sudo alsa force-reload [sudo] password for user1: Unloading ALSA sound driver modules: (none loaded). Loading ALSA sound driver modules: (none to reload).modprobe
$ grep intel /etc/modprobe.d/alsa-base.conf options snd-intel8x0m index=-2
(2) Related and possibly useful posts
Unable to get sound working. Ubuntu Server 14.04.3
https://forums.linuxmint.com/viewtopic.php?t=221745
https://ubuntuforums.org/showthread.php?t=1684576
How to load "snd-hda-intel" at startup
(3) Other related posts
https://www.alsa-project.org/wiki/Matrix:Module-hda-intel
https://askubuntu.com/a/1244118/226614 . Recent post, accepted answer. Suggests using a ppa for fixing. I am not sure this can get things worse...
https://askubuntu.com/a/1249071/226614 . Recent post. Suggests using sudo setfacl -m u:user1:rw /dev/snd/* Tried this, didn't help.
https://askubuntu.com/a/847954/226614 . Old post, accepted answer. Suggests installing alsa-firmware-loaders and alsa-base. I am not sure this still applies...
How to install missing firmware for an Creative Labs Audigy2 soundcard? . Also old post. Also suggests UNCLAIMED device is due to firmware issues.
Why would the problem appear after a reboot?
No sound on upgrade (18.04 -> 20.04) only have "dummy output"
Dummy output after standby since upgrading to Ubuntu 20.04
Internal speaker (Audio) is not working in Ubuntu 20.04 LTS after upgrading from Ubuntu 18.04 LTS
Soundcard not detected by pulseaudio (but by alsa)
