I had installed Gstreamer and ALSA plugins to work on some experiments. Steps followed for the installation of the plugin: https://tsn.readthedocs.io/avb.html#plugins-installation
However, after the installation was completed I restarted my PC after which the audio has stopped working. In the setting in the output device, dummy output shows up while for the input device there is no option. I have dual boot in my system so, in Windows, the audio works fine, thus it's clearly not a hardware problem.
I uninstalled the plugins as well as tried reinstalling Ubuntu audio drivers, however, the issue still persists. I believe while setting up the plugins some configuration has changed.
Ubuntu Version: 20.04
Linux Kernel Version: 5.11.0-27-generic
Any help would be highly appreciated.
There is a range of possible causes
You could try
  1. Updating the kernel and/or installing linux-modules-extra
  2. alsa
     sudo apt install --reinstall alsa-base pulseaudio
     sudo alsa force-reload
  3. timidity
     sudo apt purge timidity-daemon
  4. Driver config
     echo "options snd-hda-intel model=generic" | sudo tee -a /etc/modprobe.d/alsa-base.conf
     echo "options snd-hda-intel dmic_detect=0" | sudo tee -a /etc/modprobe.d/alsa-base.conf
If the above doesn't work, I suggest you add all output listed in Only "Dummy output" (sound) in Ubuntu 20.04 after reboot - Broken driver / module . It would take you some 5 minutes...
