after the installation sound system is not working and check the settings it shows only "Dummy Output".HERE THE INFO
    Subsystem: Xiaomi Device 2309
    Flags: bus master, fast devsel, latency 0, IOMMU group 1
    Capabilities: <access denied>
    Kernel driver in use: igen6_edac
    Kernel modules: igen6_edac
00:02.0 VGA compatible controller: Intel Corporation Meteor Lake-P [Intel Arc Graphics] (rev 08) (prog-if 00 [VGA controller]) Subsystem: Xiaomi Meteor Lake-P [Intel Arc Graphics] Flags: bus master, fast devsel, latency 0, IRQ 197, IOMMU group 0 Memory at 4818000000 (64-bit, prefetchable) [size=16M] Memory at 4000000000 (64-bit, prefetchable) [size=256M] Expansion ROM at 000c0000 [virtual] [disabled] [size=128K] Capabilities: <access denied> Kernel driver in use: i915 Kernel modules: i915, xe
00:04.0 Signal processing controller: Intel Corporation Device 7d03 (rev 04) Subsystem: Xiaomi Device 2309 Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 2 Memory at 4819280000 (64-bit, non-prefetchable) [size=128K] Capabilities: <access denied> Kernel driver in use: proc_thermal_pci Kernel modules: processor_thermal_device_pci
00:06.0 PCI bridge: Intel Corporation Device 7e4d (rev 20) (prog-if 00 [Normal decode]) Subsystem: Xiaomi Device 2309 Flags: bus master, fast devsel, latency 0, IRQ 122, IOMMU group 3 Bus: primary=00, secondary=01, subordinate=01, sec-latency=0 I/O behind bridge: [disabled] [16-bit] Memory behind bridge: 86000000-860fffff [size=1M] [32-bit] Prefetchable memory behind bridge: [disabled] [64-bit] Capabilities: <access denied> Kernel driver in use: pcieport
00:07.0 PCI bridge: Intel Corporation Meteor Lake-P Thunderbolt 4 PCI Express Root Port #1 (rev 10) (prog-if 00 [Normal decode]) Subsystem: Xiaomi Meteor Lake-P Thunderbolt 4 PCI Express Root Port Flags: bus master, fast devsel, latency 0, IRQ 123, IOMMU group 4 Bus: primary=00, secondary=02, subordinate=2b, sec-latency=0 I/O behind bridge: 3000-3fff [size=4K] [16-bit] Memory behind bridge: 80000000-85ffffff [size=96M] [32-bit] Prefetchable memory behind bridge: 4010000000-480fffffff [size=32G] [32-bit] Capabilities: <access denied> Kernel driver in use: pcieport
00:08.0 System peripheral: Intel Corporation Device 7e4c (rev 20) Subsystem: Xiaomi Device 2309 Flags: fast devsel, IRQ 255, IOMMU group 5 Memory at 48192d2000 (64-bit, non-prefetchable) [disabled] [size=4K] Capabilities: <access denied>
00:0a.0 Signal processing controller: Intel Corporation Device 7d0d (rev 01) Subsystem: Xiaomi Device 2309 Flags: fast devsel, IOMMU group 6 Memory at 4819240000 (64-bit, non-prefetchable) [size=256K] Capabilities: <access denied> Kernel driver in use: intel_vsec Kernel modules: intel_vsec
00:0b.0 Processing accelerators: Intel Corporation Meteor Lake NPU (rev 04) Subsystem: Xiaomi Device 2309 Flags: bus master, fast devsel, latency 0, IRQ 175, IOMMU group 7 Memory at 4810000000 (64-bit, non-prefetchable) [size=128M] Memory at 48192d1000 (64-bit, non-prefetchable) [size=4K] Capabilities: <access denied> Kernel driver in use: intel_vpu Kernel modules: intel_vpu
00:0d.0 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 USB Controller (rev 10) (prog-if 30 [XHCI]) Subsystem: Xiaomi Meteor Lake-P Thunderbolt 4 USB Controller Flags: bus master, medium devsel, latency 0, IRQ 151, IOMMU group 8 Memory at 48192b0000 (64-bit, non-prefetchable) [size=64K] Capabilities: <access denied> Kernel driver in use: xhci_hcd Kernel modules: xhci_pci
00:0d.2 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 NHI #0 (rev 10) (prog-if 40 [USB4 Host Interface]) Subsystem: Xiaomi Meteor Lake-P Thunderbolt 4 NHI Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 8 Memory at 4819200000 (64-bit, non-prefetchable) [size=256K] Memory at 48192d0000 (64-bit, non-prefetchable) [size=4K] Capabilities: <access denied> Kernel driver in use: thunderbolt Kernel modules: thunderbolt
00:12.0 Serial controller: Intel Corporation Device 7e45 (rev 20) (prog-if 00 [8250]) Subsystem: Xiaomi Device 2309 Flags: bus master, fast devsel, latency 0, IRQ 125, IOMMU group 9 Memory at 48192a0000 (64-bit, non-prefetchable) [size=64K] Capabilities: <access denied> Kernel driver in use: intel_ish_ipc Kernel modules: intel_ish_ipc
00:14.0 USB controller: Intel Corporation Meteor Lake-P USB 3.2 Gen 2x1 xHCI Host Controller (rev 20) (prog-if 30 [XHCI]) Subsystem: Xiaomi Meteor Lake-P USB 3.2 Gen 2x1 xHCI Host Controller Flags: bus master, medium devsel, latency 0, IRQ 141, IOMMU group 10 Memory at 86100000 (64-bit, non-prefetchable) [size=64K] Capabilities: <access denied> Kernel driver in use: xhci_hcd Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Device 7e7f (rev 20) Subsystem: Xiaomi Device 2309 Flags: fast devsel, IOMMU group 10 Memory at 48192c8000 (64-bit, non-prefetchable) [size=16K] Memory at 48192cf000 (64-bit, non-prefetchable) [size=4K] Capabilities: <access denied>
00:14.3 Network controller: Intel Corporation Meteor Lake PCH CNVi WiFi (rev 20) Subsystem: Intel Corporation Wi-Fi 6E AX211 160MHz Flags: bus master, fast devsel, latency 0, IRQ 18, IOMMU group 11 Memory at 48192c4000 (64-bit, non-prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: iwlwifi Kernel modules: iwlwifi
00:15.0 Serial bus controller: Intel Corporation Meteor Lake-P Serial IO I2C Controller #0 (rev 20) Subsystem: Xiaomi Meteor Lake-P Serial IO I2C Controller Flags: bus master, fast devsel, latency 0, IRQ 32, IOMMU group 12 Memory at 48192ce000 (64-bit, non-prefetchable) [size=4K] Capabilities: <access denied> Kernel driver in use: intel-lpss Kernel modules: intel_lpss_pci
00:16.0 Communication controller: Intel Corporation Device 7e70 (rev 20) Subsystem: Xiaomi Device 2309 Flags: bus master, fast devsel, latency 0, IRQ 149, IOMMU group 13 Memory at 48192cd000 (64-bit, non-prefetchable) [size=4K] Capabilities: <access denied> Kernel driver in use: mei_me Kernel modules: mei_me
00:1f.0 ISA bridge: Intel Corporation Device 7e02 (rev 20) Subsystem: Xiaomi Device 2309 Flags: bus master, fast devsel, latency 0, IOMMU group 14
00:1f.3 Multimedia audio controller: Intel Corporation Meteor Lake-P HD Audio Controller (rev 20) Subsystem: Xiaomi Meteor Lake-P HD Audio Controller Flags: bus master, fast devsel, latency 32, IRQ 198, IOMMU group 14 Memory at 48192c0000 (64-bit, non-prefetchable) [size=16K] Memory at 4819000000 (64-bit, non-prefetchable) [size=2M] Capabilities: <access denied> Kernel driver in use: sof-audio-pci-intel-mtl Kernel modules: snd_hda_intel, snd_sof_pci_intel_mtl
00:1f.4 SMBus: Intel Corporation Meteor Lake-P SMBus Controller (rev 20) Subsystem: Xiaomi Meteor Lake-P SMBus Controller Flags: medium devsel, IRQ 18, IOMMU group 14 Memory at 48192cc000 (64-bit, non-prefetchable) [size=256] I/O ports at efa0 [size=32] Kernel driver in use: i801_smbus Kernel modules: i2c_i801
00:1f.5 Serial bus controller: Intel Corporation Meteor Lake-P SPI Controller (rev 20) Subsystem: Xiaomi Meteor Lake-P SPI Controller Flags: fast devsel, IOMMU group 14 Memory at 7e800000 (32-bit, non-prefetchable) [size=4K] Kernel driver in use: intel-spi Kernel modules: spi_intel_pci
01:00.0 Non-Volatile memory controller: Shenzhen Longsys Electronics Co., Ltd. FORESEE XP2000, Lexar NM760 NVME SSD (DRAM-less) (rev 03) (prog-if 02 [NVM Express]) Subsystem: Shenzhen Longsys Electronics Co., Ltd. Lexar NM760 NVME SSD (DRAM-less) Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 15 Memory at 86000000 (64-bit, non-prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: nvme Kernel modules: nvme
This helped me
  • Check ALSA Settings: Open a terminal and run alsamixer to check if the sound levels are correctly set. Make sure none of the channels are muted.
  • Verify Kernel Modules: Ensure all necessary sound modules are loaded. You can do this by running sudo modprobe snd-hda-intel and sudo modprobe snd-sof-pci-intel-mtl.
  • Update System Packages: Update all system packages to the latest versions using sudo pacman -Syu.
  • Configure GRUB: Edit the GRUB configuration file to disable dmic_detect for snd_hda_intel.
    sudo nano /etc/default/grub
  • Change the line in /etc/default/grub GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" to GRUB_CMDLINE_LINUX_DEFAULT="loglevel=3 quiet snd_hda_intel.dmic_detect=0"
  • Then update the GRUB configuration with
    sudo grub-mkconfig -o /boot/grub/grub.cfg
  • Enable and Start Services: Enable and start the necessary services with
    systemctl --user enable wireplumber systemctl --user start wireplumber
  • Reboot: Reboot your system to apply all changes.
