I have an HP 15z-fc000 that won't play sound from its built-in speakers after a warm boot (i.e., after doing "reboot"). It works fine after a cold boot (i.e., after doing "shutdown", waiting for it to turn completely off, and then turning it back on with the power button). When it's not working, the name of the output device I see is "Dummy output". Here's the relevant device from lspci -vvvnn from a warm boot when it's broken:
03:00.6 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller [1022:15e3]
        Subsystem: Hewlett-Packard Company Family 17h (Models 10h-1fh) HD Audio Controller [103c:8b2f]
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin C routed to IRQ 54
        IOMMU group: 17
        Region 0: Memory at fccc0000 (32-bit, non-prefetchable) [size=32K]
        Capabilities: [48] Vendor Specific Information: Len=08 <?>
        Capabilities: [50] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [64] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <4us, L1 unlimited
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
                DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
                        RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
                        MaxPayload 256 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
                LnkCap: Port #0, Speed 16GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
                LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 16GT/s (ok), Width x16 (ok)
                        TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR-
                         10BitTagComp+ 10BitTagReq- OBFF Not Supported, ExtFmt+ EETLPPrefix+, MaxEETLPPrefixes 1
                         EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
                         FRS- TPHComp- ExtTPHComp-
                         AtomicOpsCap: 32bit- 64bit- 128bitCAS-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- OBFF Disabled,
                         AtomicOpsCtl: ReqEn-
                LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete- EqualizationPhase1-
                         EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
                         Retimer- 2Retimers- CrosslinkRes: unsupported
        Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
                Address: 0000000000000000  Data: 0000
        Capabilities: [100 v1] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
        Capabilities: [2a0 v1] Access Control Services
                ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
                ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel
On cold boots when it's working, it has DisINTx+ instead of DisINTx-, MSI: Enable+ instead of MSI: Enable-, and Address: 00000000fee00000 instead of Address: 0000000000000000.
On warm boots when it's broken, I don't see this device in aplay -l at all, but on cold boots when it's working, it appears there like this:
card 1: Generic_1 [HD-Audio Generic], device 0: ALC236 Analog [ALC236 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
I've tried on both Ubuntu 22.04 (a clean installation, not an upgrade from an older version) and 23.04 (from a live USB), and neither one works. I'm happy to use either, should there be a solution that works on one but not the other. Here's some other things I tried, and the results:
  • Adding snd-hda-intel.model=generic to the kernel command line, or appending options snd-hda-intel model=generic to /etc/modprobe.d/alsa-base.conf - Changes the output device I see to "HD-Audio Generic Digital Stereo (HDMI)", but I still can't hear anything played through it.
  • Adding snd-hda-intel.dmic_detect=0 to the kernel command line, or appending options snd-hda-intel dmic_detect=0 to /etc/modprobe.d/alsa-base.conf - No noticeable change
  • Both of the above at the same time - No noticeable change beyond what the first one did alone
  • Booting the 6.3.0 mainline kernel from https://kernel.ubuntu.com/~kernel-ppa/mainline/v6.3/amd64/ - No noticeable change
  • pulseaudio --kill followed by pulseaudio --start: PulseAudio never comes back up and I can't even see sound preferences anymore until I reboot
  • sudo touch /usr/share/pipewire/media-session.d/with-pulseaudio followed by systemctl --user restart pipewire-session-manager: No noticeable change
I'm out of ideas. What should I try/do next?
There exists a sort of "canonical set" of commands that I wrote, and it helped many others diagnosing (and then solving) audio issues. In particular, if you see "Dummy output".
Please check Only "Dummy output" (sound) in Ubuntu 20.04 after reboot - Broken driver / module and post whatever results you find.
The same problem with the same laptop. First time it works, then after reboot - it does not (dummy output). What I found additionally is that Ubuntu 21.10 still works fine at least in this respect (i.e., you can reboot without any issues). However, Ubuntu 22.04 (the very first release) with Linux 5.15 does not work fine any more. If I remember correctly, Ubuntu 21.10 still used Linux 5.13. That means the issue was most likely introduced in the driver somewhere in between 5.13 and 5.15.
Another thing I noticed is that sound device identifiers are enumerated differently:
  1. In Ubuntu 22.04+, we have:
cat /sys/class/sound/hwC1D0/subsystem_id : 0xaa0100
cat /sys/class/sound/hwC2D0/subsystem_id : 0x103c8b30
  1. In Ubuntu 21.10, we have:
cat /sys/class/sound/hwC0D0/subsystem_id : 0xaa0100
cat /sys/class/sound/hwC1D0/subsystem_id : 0x103c8b30
Note that in Ubuntu 21.10 it starts from hwC0D0, but in Ubuntu 22.04+ it starts from hwC1D0. Furthermore, after reboot hwC2D0 completely disappears.
Is the codec (hwC2D0) is somehow powered off when the driver is unloaded?
Ruslan
After receiving a helpful bit of information from Ruslan, namely that this used to work fine in prior Ubuntu versions, I managed to confirm that this is a kernel regression caused by commit 5aec98913095ed3b4424ed6c5fdeb6964e9734da. I reported this as https://bugzilla.kernel.org/show_bug.cgi?id=217440 and am working around it for now by doing a custom kernel build with that change reverted. Regzbot link: https://linux-regtracking.leemhuis.info/regzbot/regression/bugzilla.kernel.org/217440/
