205
How can I completely remove all traces of Java on my system?
I already know how to install it in case I need it again.
CaldwellYSR
  • 2,217
9 Answers9
425
  1. Remove all the Java related packages (Sun, Oracle, OpenJDK, IcedTea plugins, GIJ):
    dpkg-query -W -f='${binary:Package}\n' | grep -E -e '^(ia32-)?(sun|oracle)-java' -e '^openjdk-' -e '^icedtea' -e '^(default|gcj)-j(re|dk)' -e '^gcj-(.*)-j(re|dk)' -e '^java-common' | xargs sudo apt-get -y remove
    sudo apt-get -y autoremove
  2. Purge config files (careful. This command removed libsgutils2-2 and virtualbox config files too):
    dpkg -l | grep ^rc | awk '{print($2)}' | xargs sudo apt-get -y purge
  3. Remove Java config and cache directory:
    sudo bash -c 'ls -d /home/*/.java' | xargs sudo rm -rf
  4. Remove manually installed JVMs:
    sudo rm -rf /usr/lib/jvm/*
  5. Remove Java entries, if there is still any, from the alternatives:
    for g in ControlPanel java java_vm javaws jcontrol jexec keytool mozilla-javaplugin.so orbd pack200 policytool rmid rmiregistry servertool tnameserv unpack200 appletviewer apt extcheck HtmlConverter idlj jar jarsigner javac javadoc javah javap jconsole jdb jhat jinfo jmap jps jrunscript jsadebugd jstack jstat jstatd native2ascii rmic schemagen serialver wsgen wsimport xjc xulrunner-1.9-javaplugin.so; do sudo update-alternatives --remove-all $g; done
  6. Search for possible remaining Java directories:
    sudo updatedb
    sudo locate -b '\pack200'
    If the command above produces any output like /path/to/jre1.6.0_34/bin/pack200 remove the directory that is parent of bin, like this: sudo rm -rf /path/to/jre1.6.0_34.
Nav
  • 1,149
  • 13
  • 26
Eric Carvalho
  • 55,453
52
To completely remove OpenJDK on Ubuntu 11.10 (this may or may not be sufficient on other versions of Ubuntu), run:
sudo apt-get purge openjdk-\* icedtea-\* icedtea6-\*
If you want instructions for removing the proprietary Oracle ("Sun") version of Java, then you'll have to specify how you installed it. (If you edit your question to indicate this and leave a comment to this answer, I'll try to add information about how to remove that too.)
Eliah Kagan
  • 119,640
31
To uninstall Oracle Java 7, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command below.
sudo update-alternatives --display java
To check the setup before uninstalling Java.
Next, remove symlinks
(replace the word (version)with your Java version. DO java -version to get yours. So if your version is 1.7.0_03, you would type sudo update-alternatives --remove "java" "/usr/lib/jvm/jdk1.7.0_03/bin/java")
sudo update-alternatives --remove "java" "/usr/lib/jvm/jdk<version>/bin/java"
sudo update-alternatives --remove "javac" "/usr/lib/jvm/jdk<version>/bin/javac"
sudo update-alternatives --remove "javaws" "/usr/lib/jvm/jdk<version>/bin/javaws"
verify that the symlinks were removed
java -version
javac -version
which javaws
The next 2 commands must be type excatly perfectly to avoid permanently destroying your system.
cd /usr/lib/jvm
sudo rm -rf jdk<version>
Then do
sudo update-alternatives --config java
sudo update-alternatives --config javac
sudo update-alternatives --config javaws
Then do
sudo vi  /etc/environment
Delete the line with JAVA_HOME 1
To uninstall OpenJDK (if installed). First check which OpenJDK packages are installed.
sudo dpkg --list | grep -i jdk
To remove openjdk:
sudo apt-get purge openjdk*
Uninstall OpenJDK related packages.
sudo apt-get purge icedtea-* openjdk-*
Check that all OpenJDK packages have been removed.
1Source:akbarahmed.com
Mitch
  • 109,787
18
You may not need to completely remove the OpenJDK to resolve your problem. Install the sun-java6 packages. Then use update-java-alternatives to switch to the Sun java packages.
If you do want to completely remove OpenJDK remove the default-jdk and/or default-jre packages. You may need to remove some java packages but most of them should be happy once you have the Sun JDK packages installed.
You may want to follow one of these cleanup tips once you are done removing packages.
BillThor
  • 4,698
Try this command:
java -version
If 1.6* comes then try:
sudo apt-get autoremove openjdk-6-jre
If 1.7* comes then try:
sudo apt-get autoremove openjdk-7-jre
Assuming that you don't have jdk in your system. If you have use this command:
sudo apt-get autoremove openjdk-`<version>`-jdk
replace with the version like we did it in previous example.
Aaron
  • 6,764
Pranit Bauva
  • 1,101
easier is to use synaptic.
click tab "sections" scroll down to java. simply select each item you see with green box and mark for complete removal. repeat for all all java sections and all files.
rob grune
  • 1,161
With JDK 18
sudo apt-get autoremove openjdk-18-jdk
Just remove all files of JDK or JRE, for example it's usually installed in this location:
/usr/lib/jvm/java-7-oracle
So remove all files resides in "java-7-oracle" folder with root permission and extract the latest JDK or JRE files in it. That's it now you would have the latest Java version Installed.
P.S. Your directory name may differ from java-7-oracle.
Reference: Official installation instruction from Oracle
Agreed with Eliah. "apt-get purge" command can remove those packages completely.
Assuming you have previously installed a copy of java-6-sun package, a followup will help getting rid of broken symbolic link:
And then select a correct path which you want to link up as default Java calling path.
Then have a check on the version of Java with this command:
java -version
Eliah Kagan
  • 119,640
code_x747
  • 111
