Showing the message
'tools.jar' seems to be not in Android Studio classpath. Please ensure JAVA_HOME points to JDK rather than JRE.
how can i solve it
show me how install jdk properly
saif rind
You can install JDK using following command :
sudo apt-get install openjdk-7-jdk
And then run
sudo update-alternatives --config java
command and select JDK instead of JRE. And then try to run
studio.sh
Hope it helps
  1. Ensure you've installed the java sdk, and not just the jre
  2. Ensure the JAVA_HOME environment path has the correct path after the sdk is installed
snurfle
  • 121
I removed android studio, Umake and zip. Then I followed the instructions on this link How to completely uninstall Java?. Then installed java7 jdk form software center. Finally i re-installed android studio using umake. Now it works like a charm!
