i run ubuntu 16.04 and i am trying to execute 'minecraft.jar' located at my desktop. i right click and choose to open it using 'JDK java 8 runtime' but no luck. i then try to execute from the terminal:
s@s-Inspiron-3543:~/Desktop$ java -jar Minecraft.jar
and get the following message:
The program 'java' can be found in the following packages:
* default-jre
* gcj-5-jre-headless
* openjdk-8-jre-headless
* gcj-4.8-jre-headless
* gcj-4.9-jre-headless
* openjdk-9-jre-headless
Try: sudo apt install <selected package>
so, i installed and again i get the same... when i check for the java version:
 s@s-Inspiron-3543:~$ update-java-alternatives -l
i get either
java-1.8.0-openjdk-amd64    1081  /usr/lib/jvm/java-1.8.0-openjdk- amd64
or if i use the 'java version' again i am told where to install it from...
any ideas???
thanks in advance : )
Java 9, OpenJDK or otherwise, is still under development, last I checked, and is very likely to be buggy - it's very very likely this is due to you using Java 9 and not a Stable Release of Java (such as Java 8).
Consider switching back to Java 8, and not use Java 9 since it's still in 'development' and not yet released. (This applies to Oracle Java as well).
Failing that, remove all Java packages, and try reinstalling them all with:
sudo apt-get install -y openjdk-8-jre openjdk-8-jdk
... which should install all the Java 8 files again and make it usable once again.
Thomas Ward
  • 78,878
