Java HotSpot(TM) Server VM warning:
You have loaded library /tmp/libnetty-transport-native-epoll7650900490225298142.so
 which might have disabled stack guard.
The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with
'execstack -c <libfile>', or link it with '-z noexecstack'.`
This shows up on startup of my Minecraft server
Ubuntu 14.04LTS 32bit java1.8.0_40
I tried uninstalling java completely.
And reinstalling.
'execstack' is not a command in terminal or java
Is there a fix for this?
Zanna
  • 72,312
Myst
  • 133
Just attempted to correct this issue on my server.
Did the following:
sudo apt-get update
sudo apt-get install prelink
then ran the execstack command only to be told the file doesn't exist
Manually checked the /tmp directory and the file does not exist so it wasn't a path error.
How a file can be loaded that doesn't exist is a puzzle unless it was loaded during a java update and then erased....
Zanna
  • 72,312
Guy_D
