I use Ubuntu 14.04 LTS, 64-bit. In attempt to run some 32-bit programs, I had to install java version 6. Java version 7 was already present. I used update-alteratives to switch between them. Somehow I messed up completely and want to remove all contents of both versions of java and re-install. I used apt-get remove but I think some parts of java are being left over.
Question : How do I remove java from scratch from my ubuntu system ?
Any help is highly appreciated. TIA.
node_analyser
  • 261
The following solution removes all Java installations (OpenJDK and Oracle Java), installed via the Package Manager
  1. Check the output of the commands below and check twice if it's ok to remove
    dpkg --get-selections | awk '/oracle-java/ && /installer/ {print "sudo apt-get purge "$1}'
    dpkg --get-selections | awk '/openjdk/ {print "sudo apt-get -y purge "$1}'
  2. After that purge OpenJDK and Oracle Java via
    dpkg --get-selections | awk '/oracle-java/ && /installer/ {system("sudo apt-get purge "$1)}'
    dpkg --get-selections | awk '/openjdk/ {system("sudo apt-get -y purge "$1)}'
A.B.
  • 92,125
use apt-get purge to remove anything including configs and alike.
If the problems persist, you can always use find -name '*java*' or to find any java remainders. Note that you might also need to search for e.g. jvm (java virtual machine) and that find will allow deleting, but use this command with care.
Alternatively you can always force a reinstall: apt-get install --reinstall package-name
This could cure the problems with your java.
FelixJN
  • 2,438
I'm not fully sure what you understand by "some parts of java are remaining on my system", but running these 2 commands will tell you what's installed relatively to java and the openjdk VM.
dpkg --get-selections | grep java
dpkg --get-selections | grep jdk
Lots of "java"-tagged packages are actually libraries and bindings, you probably don't care much about those. The core of the java is in the commons i think.
Also, maybe your problem comes from leftover config files... don't forget to apt-get purge your packages!
